Hi all, I have to demodulate an O-QPSK signal. As usual in this kind of modulation, symbols (chips) have an half-sine shape, and the Q channel has a 90 degree (half simbol) offset with respect to the I channel. The first thing I have to do (and perhaps the most difficult) is removing the frequency offset from the received I and Q signals. I cannot use a simple Costas loop since it doesn't work with O-QPSK signals! Are there dedicated loops for O-QPSK signals? Or it exists some simple and effective way to demodultate such a signal? Thank you in advance for any advice! Antonio
O-QPSK Demodulation
Started by ●December 18, 2005
Reply by ●December 18, 20052005-12-18
A.D. wrote:> Hi all, > I have to demodulate an O-QPSK signal. As usual in this kind of > modulation, symbols (chips) have an half-sine shape, and the Q channel > has a 90 degree (half simbol) offset with respect to the I channel. > The first thing I have to do (and perhaps the most difficult) is > removing the frequency offset from the received I and Q signals. I > cannot use a simple Costas loop since it doesn't work with O-QPSK > signals! > Are there dedicated loops for O-QPSK signals? Or it exists some simple > and effective way to demodultate such a signal?The demodulation of OQPSK is not much different from the demodulation of the QPSK. Think of OPSK as of two BPSK signals shifted by 1/2 bit. All you have to do is to jointly demodulate those two signals. Symbol sync and carrier sync is not any different. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
A.D. wrote:> Hi all, > I have to demodulate an O-QPSK signal. As usual in this kind of > modulation, symbols (chips) have an half-sine shape, and the Q channel > has a 90 degree (half simbol) offset with respect to the I channel. > The first thing I have to do (and perhaps the most difficult) is > removing the frequency offset from the received I and Q signals. I > cannot use a simple Costas loop since it doesn't work with O-QPSK > signals! > Are there dedicated loops for O-QPSK signals? Or it exists some simple > and effective way to demodultate such a signal? > > Thank you in advance for any advice! > Antonio >O-QPSK with half-sine shaping also goes by the name 'MSK'. I built an MSK radio modem for my Master's thesis, which I have recently posted on the web: http://www.wescottdesign.com/articles/MSK/mskTop.html. Chapter 3 should give a pretty good tutorial for how to do this, and Appendix B is a pretty good example of just how execrable code can be while still functioning as intended. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●December 19, 20052005-12-19
"Vladimir Vassilevsky" <antispam_bogus@hotmail.com> ha scritto nel messaggio news:i9kpf.39953$tV6.22464@newssvr27.news.prodigy.net...> > The demodulation of OQPSK is not much different from the demodulation of > the QPSK. Think of OPSK as of two BPSK signals shifted by 1/2 bit. All you > have to do is to jointly demodulate those two signals. Symbol sync and > carrier sync is not any different.Thank you Vladimir, I will try it. Regards, Antonio
"Tim Wescott" <tim@seemywebsite.com> ha scritto nel messaggio news:bMydnWHsbLEEdzjeRVn-uA@web-ster.com...> > O-QPSK with half-sine shaping also goes by the name 'MSK'. I built an MSK > radio modem for my Master's thesis, which I have recently posted on the > web: http://www.wescottdesign.com/articles/MSK/mskTop.html. Chapter 3 > should give a pretty good tutorial for how to do this, and Appendix B is a > pretty good example of just how execrable code can be while still > functioning as intended.Great! I will carefully read it. Thank you very much, Antonio
A.D. wrote:> Hi all, > I have to demodulate an O-QPSK signal. As usual in this kind of > modulation, symbols (chips) have an half-sine shape, and the Q channel > has a 90 degree (half simbol) offset with respect to the I channel. > The first thing I have to do (and perhaps the most difficult) is > removing the frequency offset from the received I and Q signals. I > cannot use a simple Costas loop since it doesn't work with O-QPSK > signals! > Are there dedicated loops for O-QPSK signals? Or it exists some simple > and effective way to demodultate such a signal? > > Thank you in advance for any advice! > Antoniohow big do you expect the offset to be?, I believe differential chip detection can handle some offset but it will cost you a little over 3dB in sensitivity -Lasse
Reply by ●December 20, 20052005-12-20
<langwadt@ieee.org> ha scritto nel messaggio news:1135022040.250858.304390@g43g2000cwa.googlegroups.com...> > how big do you expect the offset to be?, I believe differential chip > detection can handle some offset but it will cost you a little over > 3dB in sensitivityI'm trying to demodulate ZigBee signals, so I have a chip rate of 1Mcps on I and Q channel and a maximum extimated offset of about 500KHz (wrost case). But data are not differentially encoded, so I think that is not possible to use a differential detection... Regards, Antonio
