Digital filter simulators?
Started by Joerg ●December 18, 2005
Try Octave! The syntax is very much similar to MATLAB
Hello Sivakanth,
> Try Octave! The syntax is very much similar to MATLAB >
Would love to. But I am not a great MATLAB user either. I need something that is simple, like some of the configurable FFT programs out there. A few of these almost do what I need but stop just short of coefficient granularization. Regards, Joerg http://www.analogconsultants.com
Hello Tim,
> > If someone would fund me, and if I thought the Scilab team would pay > attention, I'd love to dig in and write _good_ documentation for that > package. >
That's exactly the point. Many excellent SW packages and even some uC are so poorly documented that they don't make it into mainstream for that reason. Academians often won't go below the highest level of abstraction and there are no "Heathkit style" grunt work examples. But all this will be needed to get engineers on board. Especially the busy ones who can't spend weeks reading up on stuff. Even in many books it's like that. My favorite here is Haddad Parsons but when it comes to practical implementation they immediately assume you can always have the horsepower of a TMS320. Well, it just ain't so with most projects. Sometimes you'll simply have to concede and accept that there absolutely will not be a HW multiplier because it's 50 cents too much. It is like the farmer who has to make do with his old F250 because he can't have that new truck with the Cummins in there. Regards, Joerg http://www.analogconsultants.com
Joerg wrote:
> I have some filter design software that came with DSP books but they > don't go that far. They assume 'ideal' coefficient granularity base on > the available word width. Didn't find anything with Google but maybe I > hadn't used optimal search phrases.
Out of curiosity: What is "coefficient granularity"? Never heard the term before. Rune
Joerg wrote:
> Hello Tim, > > > > > If someone would fund me, and if I thought the Scilab team would pay > > attention, I'd love to dig in and write _good_ documentation for that > > package. > > > > That's exactly the point. Many excellent SW packages and even some uC > are so poorly documented that they don't make it into mainstream for > that reason. Academians often won't go below the highest level of > abstraction and there are no "Heathkit style" grunt work examples. But > all this will be needed to get engineers on board. Especially the busy > ones who can't spend weeks reading up on stuff.
Academics don't know what the term "documentation" means. A couple of weeks ago, the professor who took up the methods and techniques I used to work with, called me and wanted to discuss some questions. The questions concerned a computer I last worked with 5 years ago, that I got 10 years ago from somebody who had modified 15 years old public domain code. The "documentation" of the original PD code consisted of a 6-page short summary of a general technique, where some variables were stated "without proof". In the program (Fortran 77) the variables were named as "acc", "bb", "cmn"... with no comments and apparently with no connection to the article. The program was written in the "implicit declaration" style that fortran allows, where a variable needs not be declared but where its data type (real, complex, integer) is implicitly given by its name. An utter nightmare. The professor had spent two months getting the thing to compile and run, due to the less than standardized way fortran works. It would have been way faster to write the program from scratch. I'm happy that other people take over those tasks; I'm pretty fed up with the stuff. But if I ever get a call like that again, I'll charge $250 per hour. So what I have done in my programming projects, is to write the basics in LaTeX and document the code so that HTML documents can be generated with Doxygen. These tools are free, and are available to students, but can not necessarily be used by companies. Are there alternatives available that can be used in commercial projects, that can be used for other programming languages than C/C++? Rune
Hello Rune,
> So what I have done in my programming projects, is to write the > basics in LaTeX and document the code so that HTML documents > can be generated with Doxygen. These tools are free, and are > available to students, but can not necessarily be used by companies. > Are there alternatives available that can be used in commercial > projects, > that can be used for other programming languages than C/C++? >
No idea, I don't code much. But if I do I document everything in HTML. Code, module specs, schematics, revision history and so on. I am a strong believer that source code comments are not a sufficient form of documentation. Regards, Joerg http://www.analogconsultants.com
Rune Allnor wrote:
> Joerg wrote: > >>I have some filter design software that came with DSP books but they >>don't go that far. They assume 'ideal' coefficient granularity base on >>the available word width. Didn't find anything with Google but maybe I >>hadn't used optimal search phrases. > > > Out of curiosity: What is "coefficient granularity"? > Never heard the term before. > > Rune >
Jeorg: You mean quantization, right? You shouldn't overlook data quantization, either. Both coefficient and data quantization can be easily modeled and analyzed without having to simulate, although its usually a good idea to simulate so you'll find out what you forgot to account for. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Hello Rune,
The reduction of the total available number of coefficients to less than the word width would theoretically allow. IOW causing the selection to be more granular than usual. For example let's say a certain project cannot afford a device with a HW multiplier and must also run on batteries, limiting the processor clock frequency. To save on processor cycles the amount of ones in an eight bit data word that is to be used as a multiplier may have to be limited to, say, four or five. Granularity is probably not a common word in the DSP world. It is often used in radar and ultrasound beamforming which is my home turf. Regards, Joerg http://www.analogconsultants.com
Hello Tim,
> Jeorg: You mean quantization, right? >
Kind of. It's like picking the low hanging fruit, coefficients that have the least number of ones in there. I have pretty much given up on the luxury of a HW multiplier for the project at hand (or the proposal thereof). Too expensive.
> You shouldn't overlook data quantization, either. Both coefficient and > data quantization can be easily modeled and analyzed without having to > simulate, although its usually a good idea to simulate so you'll find > out what you forgot to account for. >
True. In my case it might not easily work though because I have to filter first and then 'level select'. I need a huge dynamic range. Ranging before the filters would cost too much precious horsepower and RAM. So data will be 16 bits while the coefficients are probably going to have to be 6-8 bits. Regards, Joerg http://www.analogconsultants.com
Joerg wrote:
> Hello Rune, > >> >> Out of curiosity: What is "coefficient granularity"? >> Never heard the term before. >> > > The reduction of the total available number of coefficients to less than > the word width would theoretically allow. IOW causing the selection to > be more granular than usual. > > For example let's say a certain project cannot afford a device with a HW > multiplier and must also run on batteries, limiting the processor clock > frequency. To save on processor cycles the amount of ones in an eight > bit data word that is to be used as a multiplier may have to be limited > to, say, four or five. > > Granularity is probably not a common word in the DSP world. It is often > used in radar and ultrasound beamforming which is my home turf. > > Regards, Joerg > > http://www.analogconsultants.com
You should stick to "quantization" if you want us poor DSP types to understand. Restricting the precision of the multiplication to save time works for me. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
