As a thesis project, Im designing a piece counter using matlab. I have to count how many metal pieces are in a given image. All metal pieces are the same type, and can be touching each other. I have tried converting the color image to Black and white, eroding to stop the pieces from touching, closing the holes in the pieces and then counting, but its no use. How about trying to identify a feature of the pieces... I made an image so you can see what im talking about: Size is 53Kbytes. http://us.f1.yahoofs.com/bc/28befec/bc/Cobre/Imagen+002+Edited.jpg?bfaHRqDBLvO_jMhV Any Ideas on how can implement that? Thanks in advance
Counting objects in an image... how 2?
Started by ●December 21, 2005
Reply by ●December 21, 20052005-12-21
if link does not work, try the following: http://us.f1.yahoofs.com/bc/28befec/bc/Cobre/Explain.jpg?bfKaRqDBE6FyBsvY
"NightHawk" <nightstalker_099@yahoo.com> wrote in message news:nfSdnTRn-uLziDTeRVn-gQ@giganews.com...> if link does not work, try the following: > > http://us.f1.yahoofs.com/bc/28befec/bc/Cobre/Explain.jpg?bfKaRqDBE6FyBsvYBoth links don't work. You might want to read up on pattern recognition and how it relates to image processing. Cheers Bhaskar
It is hard to give any suggestion without seeing some sample images. Maybe you can get some ideas from the following page. Face Detection Project http://www.stanford.edu/class/ee368/Project_03/project_03.html
