Hi all, I was wondering if anyone can give me some information (links, forums, possible books) on audio transcoding topic. I've been assigned this task and I need a starting point. I'm generally interested in audio transcoding but more specific in G.729.A or G.729.AB to G.723.1A transcoding. Now the trick is the transcoding path should be direct without going through G.711 Many thanks
audio transcoding
Started by ●December 21, 2005
Reply by ●December 21, 20052005-12-21
Transcoding is an interesting subject, and does not need to go through G711 (u-law-, A-law) at all. I am assuming you meant PCM samples, i.e. a tandeming process of decompression & recompression. Doing that correctly is very beneficial for todays networking world which may combine different networks & standards at the same phone call, and for conferencing and mixing. It is yet another "black magic" :) There are several ways of doing that. 1. When dealing with Analysis-by-Synthesis (A-b-S) type coders such as G.729 & G.723.1, the transcoding may be performed in various A-b-S ways for best performance, but may also be done otherwise in open-loop or hybrid methods. 2. For parametric coders such as MELP or MELPe, parametric transcoding may be done in open loop and yet achieve very good performance. For an excellent practical implementation of parametric transcoding you may refer to its implementation in the MELPe standard: http://www.MELPe.com http://www.Compandent.com/melpe_faq.htm http://www.Compandent.com/products_melpe.htm Parametric transcoders are available there, between the MELPe rates of 2400, 1200 and 600 bps, and between MELPe and other parametric vocoders. Very efficient multi-channel implementations (5%-15% CPU) are also available for PC & Workstations running under Windows, Unix, Linux, MacOS etc.., in addition to a wide variety of multi-channel DSP implementation such as TMS320c54xx, TMS320c55xx, TMS320c64xx, OMAP etc.. Check up with Compandent, they have the speech coding expertise needed to provide you with the right answer & solution! Cheers, NS DragosD wrote:> Hi all, > > I was wondering if anyone can give me some information (links, forums, > possible books) on audio transcoding topic. > I've been assigned this task and I need a starting point. > I'm generally interested in audio transcoding but more specific in > G.729.A or G.729.AB to G.723.1A transcoding. > > Now the trick is the transcoding path should be direct without going > through G.711 > > Many thanks > >
