Hello , I am a new user of the TMS320C6711 DSP and i would like to know how i must do to make an fft with this device. Actually I acquire six tensions with an analog to digital converter and i would like to analyse the frequencies of these tension. Thank you per advance for your help regards Vincent.W The devices that i employed : - OSR 116 acquissition board : http://www.traquair.com/products/microline/ors116.html - 6711 board : http://www.traquair.com/products/microline/c6x11cpu.html
How to do a FFT ? Comment faire une FFT ?
Started by ●December 22, 2005
Reply by ●December 24, 20052005-12-24
I used sp_fftSPxSP. DSPF_sp_fftSpxSP(FFTLEN,&in[0],&w[0],scratch,brev,2,0,FFTLEN); This is a mixed radix, cache optimized routine specially made for c67x. You can find good docs on the internet. http://focus.ti.com/docs/apps/catalog/resources/appnoteabstract.jhtml?abstractName=spru657b The sp means single precision. The w and brev arguments will need to be calculated ahead of time. There is a tool for calculating w. You have to be very careful when using TI's optimized routines. There are many special requirements - like padding arrays and an even number of elements. I suggest you try an example in the emulator to verify it works. http://www.signalsguru.net
In article <1135443159.969136.207050@z14g2000cwz.googlegroups.com>, goldfita@signalsguru.net wrote:>I used sp_fftSPxSP. > >DSPF_sp_fftSpxSP(FFTLEN,&in[0],&w[0],scratch,brev,2,0,FFTLEN); > >This is a mixed radix, cache optimized routine specially made for c67x. > You can find good docs on the internet. >http://focus.ti.com/docs/apps/catalog/resources/appnoteabstract.jhtml?abstractN >ame=spru657bThis worked better for me. http://focus-webapps.ti.com/general/docs/sitesearch/searchsite. tsp?selectedTopic=1653260327&searchTerm=sp_fftSPxSP&Input=New+Search
