Hi, I hope this is not off topic! I'm trying to make use of the FFTW library (V3.01) but I have some difficulties working out the data types which comes with the library - and possibly the coding too! Below I have pasted in my current source code which should calculate the FFT of real input data. The input is a sinusoid signal and I'm looking for non-zero data in the output vector but all I get is zeros. I'm fairly green in terms of c++ programming so there might be some really basic problems with my code. Furthermore, I'm not really sure how to extract data from the output vector (a vector of the fftw_complex) Does anyone know how to do this? Cheers Thomas // FFT specific int N = 256; // Input test signal double input[256]; char txt[256]; for(int indx=0; indx<256; indx++) { input[indx]=cos(2.f*22.f/7.f*1000.f*(indx/20000.f)); sprintf(txt,"sample[%d]= %f",indx,input[indx]); OutputDebugString(txt); } double *in; fftw_complex *out; fftw_plan p; in = (double *)fftw_malloc(sizeof(double) * N); out = (fftw_complex *)fftw_malloc(sizeof(fftw_complex) * N); p = fftw_plan_dft_r2c_1d(N, in, out, FFTW_MEASURE); fftw_execute(p); /* repeat as needed */ fftw_destroy_plan(p); in = input; fftw_free(in); fftw_free(out); for(int indx=0; indx<256; indx++) { sprintf(txt,"re[%d]=%f,& im[%d]=%f", indx, &out[indx][0], indx, &out[indx][1]); OutputDebugString(txt); sprintf(txt,"re[%d]=%f,& im[%d]=%f", indx, out[indx][0], indx, out[indx][1]); OutputDebugString(txt); }
FFTW 3.01 and C++
Started by ●December 26, 2005
