Hello, I am doing some simulation about SC-FDE in a typical Hiperlan2 channel B environment. For each burst, the channel can be thought of as static. I use channel coding similar to 802.11 standard and interested most in QAM64 modulation. I have a question about the simulation result. When the channel is a mild frequency selective fading one, channel coding is really to improve performance. On the contrary, when channel is worse, channel coding result is even worse than that of no coding. I have seen some published simulation results about 802.11 or 802.16 use a lot of channel realizations to get an average performance curve. And, I am not sure whether it is highly possible the result of using channel coding (convolutional coding) in a worse channel cannot improve performance? What's that possibility? Besides SC-FDE, can this happen in OFDM? My concern is that the system would change the modulation format to a low level modualtion in case of worse channel because in these application channel is about static. As for as I know, the channel coding defined for QAM64 in 802.11 is not a powerful one. To evaluate an equalizer of a high level modulation in a WLAN environment, is it fair to include a lot of bad channels? Or, is it useful to get result in such a bundle of channel realizations? I have used 1/2 convolutional coding without puncturing. The result on bad channel is not good either. In 802.16, besides inner convolutional coding, there is outer RS code. I suspect if the inner convolutional coding cannot do the job, the outer RS can improve performance. Both 802.11 and 802.16 use the typical 1/2 (133,171), K=7 code. Can you tell me the effecitveness of this code in the standard defined statistical channel? I have checked scatter mapping, interleaving and channel coding. It seems there is no problem for my coding. I have two typical channel realizations from one paper, one is bad one is good. My equalizer has some problem? Could you shed some lights on this topic? Thanks in advance
Question about broadband equalizer in frequency selective fading channels
Started by ●January 4, 2006
Reply by ●January 4, 20062006-01-04
First of all, the direct encoding of the data with a conventional convolution code is not going to fit the QAM64 modulation. There is a lot of information about the codes designed specifically to be used with QAM. The key word is "set partitioning", you can also refer to the classic book of Proakis on the digital communication. Secondly, the codes you are mentioning are designed for good channels. The design goal was to accomplish the very low output BER. This is what the RS outer code is for. If the packet transmission fails it is often better to retransmit the whole packet rather then to carry the heavy FEC overhead. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com fl wrote:> Hello, > I am doing some simulation about SC-FDE in a typical Hiperlan2 channel > B environment. For each burst, the channel can be thought of as static. > I use channel coding similar to 802.11 standard and interested most in > QAM64 modulation. I have a question about the simulation result. > > When the channel is a mild frequency selective fading one, channel > coding is really to improve performance. On the contrary, when channel > is worse, channel coding result is even worse than that of no coding. I > have seen some published simulation results about 802.11 or 802.16 use > a lot of channel realizations to get an average performance curve. > > And, I am not sure whether it is highly possible the result of using > channel coding (convolutional coding) in a worse channel cannot improve > performance? What's that possibility? Besides SC-FDE, can this happen > in OFDM? My concern is that the system would change the modulation > format to a low level modualtion in case of worse channel because in > these application channel is about static. As for as I know, the > channel coding defined for QAM64 in 802.11 is not a powerful one. To > evaluate an equalizer of a high level modulation in a WLAN environment, > is it fair to include a lot of bad channels? Or, is it useful to get > result in such a bundle of channel realizations? > > I have used 1/2 convolutional coding without puncturing. The result on > bad channel is not good either. In 802.16, besides inner convolutional > coding, there is outer RS code. I suspect if the inner convolutional > coding cannot do the job, the outer RS can improve performance. Both > 802.11 and 802.16 use the typical 1/2 (133,171), K=7 code. Can you tell > me the effecitveness of this code in the standard defined statistical > channel? > > I have checked scatter mapping, interleaving and channel coding. It > seems there is no problem for my coding. I have two typical channel > realizations from one paper, one is bad one is good. My equalizer has > some problem? > > Could you shed some lights on this topic? > > Thanks in advance >
I have to add that I use frequency domain as feedforward equalizer and time domain as feedback equalizer. The criteria is MMSE. The simple frequency domain MMSE equalizer was also implemented. The results of both equalizer are similar. I have read one paper uses rate 1/4, K=4 Generator matrix:13,15,15,17, dfree=13 convolutional code for BPSK. For QAM64, are there some powerful convolutional code besides (133,171) code? Thank you for your concern
fl wrote:> I have to add that I use frequency domain as feedforward equalizer and > time domain as feedback equalizer. The criteria is MMSE. The simple > frequency domain MMSE equalizer was also implemented. The results of > both equalizer are similar.Equalizer + symbol-by-symbol demodulation is very weak method for processing the signal distorted by the selective fading channel. MLSE algorithm should be used. Go to the library and get a book on digital communications by Proakis.> > I have read one paper uses rate 1/4, K=4 Generator matrix:13,15,15,17, > dfree=13 convolutional code for BPSK.So what?> For QAM64, are there some > powerful convolutional code besides (133,171) code?There are great many good codes + constellations designed specifically for QAM. Don't reinvent the wheel, go to the library. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Thank you. As far as I know, MLSE is good, but it is too complex for a highly selective channel. Could you recommend which book talks about good codes for QAM? I have digital communication written by Proakis, Error control codes written by Shu Lin. I have still no clue about good codes for QAM. My limited coding knowledge is limited to inner convolutional code plus outer RS code, such as in DVB, 802.16 standards.
Reply by ●January 5, 20062006-01-05
