Hi All, I'm writing a program for stock trading simulation to verify something. But it will take 400 days for a simulation in my notebook (Centrino 1.6G). Big part of my program is floating point calculation/compare. My idea is transfer the loading to DSP but I'm not sure this idea is OK. Thanks for your suggestion. Jack
Use DSP for heavy floating-point calculation
Started by ●January 5, 2006
Reply by ●January 5, 20062006-01-05
Jack Huang wrote:> Hi All, > > I'm writing a program for stock trading simulation to verify something. > But it will take 400 days for a simulation in my notebook (Centrino > 1.6G). > Big part of my program is floating point calculation/compare. > My idea is transfer the loading to DSP but I'm not sure this idea is > OK. >You'd be much better of looking at exploiting a SIMD extension such as SSE on x86 or PowerPC on AltiVec. Paul
Paul Russell wrote:> Jack Huang wrote: > > > Hi All, > > > > I'm writing a program for stock trading simulation to verify something. > > But it will take 400 days for a simulation in my notebook (Centrino > > 1.6G).What is the simulation envirionment? Matlab / Scilab / Octave / R / S or the like? If so, then you'll get substantial speedup if you write a compiled program in C/C++.> > Big part of my program is floating point calculation/compare. > > My idea is transfer the loading to DSP but I'm not sure this idea is > > OK.If you need double precision (depends on what you are doing in your simulation), then DSPs are not the solution. What type of computations are used in the simulations? FFTs? IIR/FIR filtering? Dot products?> > > > You'd be much better of looking at exploiting a SIMD extension such as > SSE on x86 or PowerPC on AltiVec.This will at best reduce the simulation time to 200 days :-). Regards, Andor
Jack Huang wrote:> Hi All, > > I'm writing a program for stock trading simulation to verify something. > But it will take 400 days for a simulation in my notebook (Centrino > 1.6G). > Big part of my program is floating point calculation/compare. > My idea is transfer the loading to DSP but I'm not sure this idea is > OK.I don't know if there is anything to be gained by using the DSP, but I discovered notebooks by default run on half the max CPU frequency. There is an option under the "power adminstration"(?) tab in the control panel under windows, you can switch to let the CPU run at full speed. If you haven't flicked that switch already, you can save 200 days... Seriously, for a program on that sort of scale, I would look very carefully into programming languages (C/C++, maybe even assembly), maths libraries tailor-made for whatever HW/OS combo you are using, and maybe most importantly, parallelization. If your simulation can be parallelized (not all simulations can) then get access to, say, a large linux cluster and run your simulation there. Rune
Dear All, Single precision. Not FFT/IIr/FIR, only simple multiply/add/compare. Sorry, I use VB........that's easier for others reading. OK, I'm porting it to C. AI know, DSP is strong in ALU (that's what I want) and weak in other functions. Use Harvard architecture. But all of this is memory 10 years ago. I don't familiar in DSP field, but I need a lot of arithematic calculation power now. After searching internet, I found TI has a starter kit and cheap enough that I can afford it. So, I guess if I can porting my program to DSP, and use more then 1 DSP starter kit, then I can reduce my simulation time. Am I right? or wrong? Sorry for my bad English and thanks for your fast response. Jack
Dear Rune, Yes, it runs at full speed. and yes, I'm thinking about that (use BOINC.....and not setup successfully yet. Fighting.......) Anyway, I don't have much resource to run this simulation, and I found TI's 6711 starter kit is cheap enough that I can buy some to run this program. I hope so. Thanks. Jack
"Jack Huang" <rhuang@ms2.hinet.net> writes:> Dear Rune, > > Yes, it runs at full speed. > and yes, I'm thinking about that (use BOINC.....and not setup > successfully yet. Fighting.......) > Anyway, I don't have much resource to run this simulation, and I found > TI's 6711 starter kit is cheap enough that I can buy some to run this > program. > I hope so.I would port it to C first and see how it runs on your notebook before spending the money on a development kit, since in either case you need to port it to C. The C implementation could be significantly faster than VB. -- % Randy Yates % "My Shangri-la has gone away, fading like %% Fuquay-Varina, NC % the Beatles on 'Hey Jude'" %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Shangri-La', *A New World Record*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:> "Jack Huang" <rhuang@ms2.hinet.net> writes: > > > Dear Rune, > > > > Yes, it runs at full speed. > > and yes, I'm thinking about that (use BOINC.....and not setup > > successfully yet. Fighting.......) > > Anyway, I don't have much resource to run this simulation, and I found > > TI's 6711 starter kit is cheap enough that I can buy some to run this > > program. > > I hope so. > > I would port it to C first and see how it runs on your notebook before > spending the money on a development kit, since in either case you need > to port it to C. The C implementation could be significantly faster than > VB.Definitely. My guess is that the algorithm runs faster on the 1.6GHz notebook than on the 150MHz DSP card, once it is coded in C (as there are no fast dot-products required by Jack's algorithm, which could bring the DSP up to speed with the notebook CPU). Regards, Andor
Andor wrote:> Randy Yates wrote: > >>"Jack Huang" <rhuang@ms2.hinet.net> writes: >> >> >>>Dear Rune, >>> >>>Yes, it runs at full speed. >>>and yes, I'm thinking about that (use BOINC.....and not setup >>>successfully yet. Fighting.......) >>>Anyway, I don't have much resource to run this simulation, and I found >>>TI's 6711 starter kit is cheap enough that I can buy some to run this >>>program. >>>I hope so. >> >>I would port it to C first and see how it runs on your notebook before >>spending the money on a development kit, since in either case you need >>to port it to C. The C implementation could be significantly faster than >>VB. > > > Definitely. My guess is that the algorithm runs faster on the 1.6GHz > notebook than on the 150MHz DSP card, once it is coded in C (as there > are no fast dot-products required by Jack's algorithm, which could > bring the DSP up to speed with the notebook CPU).So you think he needs to get in touch with his inner product? :-) Steve
"Randy Yates" <yates@ieee.org> wrote in message news:oe2q4x3t.fsf@ieee.org...> "Jack Huang" <rhuang@ms2.hinet.net> writes: > > I would port it to C first and see how it runs on your notebook before > spending the money on a development kit, since in either case you need > to port it to C. The C implementation could be significantly faster than > VB.FWIW for grins I did a quick test of a loop on my trusty 700MHz laptop with each iteration including an int to double prec conversion, a double precision multiply, and a double precision add in VB and VC: VB 6 Dbg 2.8m iterations/sec VB 6 Exe 4.3m iterations/sec VC 6 Dbg 77m iterations/sec VC 6 Rel 140m iterations/sec So, C can be up to 50 times faster than VB for this test. VB: Private Sub Command1_Click() Dim t Dim l As Long t = Time Sum = 0 For l = 1 To 10000000 g = l * 3.123 Sum = Sum + g Next l Label1.Caption = Time - t End Sub VC: #include <math.h> void main(void) { double dSum=0.0; int n; for (n=0;n<1000000000;n++) { dSum+=n*3.123; } } Cheers, Howard
