any deep thinking on why linear systems are commutative?
Started by kiki ●October 25, 2004
Dear all,
Could you please help me understand better by providing some deep thoughts
If T1 and T2 are linear systems, then y1=T2(T1(x)) and y2=T1(T2(x))
y1 and y2 are the same.
After seeing some examples of non-linear system and linear systems. I got
convinced that for non-linear system this property does not hold.
But any deeper thinking? Proof?
Thanks a lot!
"kiki" <lunaliu3@yahoo.com> wrote in message
news:cljh80$btq$1@news.Stanford.EDU...
> Dear all, > > Could you please help me understand better by providing some deep thoughts > on why linear systems are commutative? > > If T1 and T2 are linear systems, then y1=T2(T1(x)) and y2=T1(T2(x)) > > y1 and y2 are the same. > > After seeing some examples of non-linear system and linear systems. I got > convinced that for non-linear system this property does not hold. > > But any deeper thinking? Proof? > > Thanks a lot! >
What exactly do you mean by a "linear system"? If you can write down a mathematical description of it, I suspect you'd have answered your own question. BUT ... There are systems that look like they're linear in which commutatively doesn't hold. Quantum Mechanics springs to mind. Does that mean it isn't linear or that all linear systems aren't commutative? Norm
On Mon, 25 Oct 2004 11:38:55 -0700, "kiki" <lunaliu3@yahoo.com> wrote:
>Dear all, > >Could you please help me understand better by providing some deep thoughts >on why linear systems are commutative? > >If T1 and T2 are linear systems, then y1=T2(T1(x)) and y2=T1(T2(x)) > >y1 and y2 are the same. > >After seeing some examples of non-linear system and linear systems. I got >convinced that for non-linear system this property does not hold. > >But any deeper thinking? Proof?
This is not true, so a proof is going to need to be _very_ deep. (Or if it's true I'm totally misunderstanding what you mean by "linear system"...)
>Thanks a lot! >
************************ David C. Ullrich
To answer the subject line: Composition of linear (time invariant) systems is convolution of their impulse responses. Now you can prove that, including the commuting part in passing, various ways so it is true for ALL LTI systems. But to prove it is not the case for nonlinear you only need ONE exception which you seem to have already found.
"David C. Ullrich" <ullrich@math.okstate.edu> wrote in message
news:eljqn010mtqq2psn2cfdln9l53plhrd8er@4ax.com...
> On Mon, 25 Oct 2004 11:38:55 -0700, "kiki" <lunaliu3@yahoo.com> wrote: > > >Dear all, > > > >Could you please help me understand better by providing some deep thoughts > >on why linear systems are commutative? > > > >If T1 and T2 are linear systems, then y1=T2(T1(x)) and y2=T1(T2(x)) > > > >y1 and y2 are the same. > > > >After seeing some examples of non-linear system and linear systems. I got > >convinced that for non-linear system this property does not hold. > > > >But any deeper thinking? Proof? > > This is not true, so a proof is going to need to be _very_ deep. > (Or if it's true I'm totally misunderstanding what you mean by > "linear system"...)
A couple of thoughts: I think you also need to add "time-invariant" to your requirement for being commutative. Maybe you were assuming a static system, but it's good to be explicit about that. Sometimes shift-invariant is used instead in a sampled data/digital system. I don't know about the general case, but for something simple such as T1 and T2 being different (linear) filters, it certainly holds. A really simple example if making a band-pass filter out of a low-pass and high-pass filter. It doesn't matter if you run the signal through the LP first and then run the result through the HP or vice versa. (I'm talking the world pure mathematics here, so things such as round-off error/quantization noise are ignored.) Are there examples where two linear time-invariant systems are not commutative? In the DSP world, the general definition for a linear system is where the principle of super-position holds. In layman's terms, put in twice the input and you get twice the output (T(g*a) = g*T(a). Or put in a + b and the answer is the same as if you put in a, then b, and added the results (T(a+b) = T(a) + T(b)). I noticed this is posted to sci.math as well, and perhaps a different definition is used there?
kiki wrote:
> Dear all, > > Could you please help me understand better by providing some deep thoughts > on why linear systems are commutative? > > If T1 and T2 are linear systems, then y1=T2(T1(x)) and y2=T1(T2(x)) > > y1 and y2 are the same. > > After seeing some examples of non-linear system and linear systems. I got > convinced that for non-linear system this property does not hold. > > But any deeper thinking? Proof? > > Thanks a lot! > >
Kiki, David, Norm: I think that Kiki means a linear system in the signal processing sense, i.e. the definition in Oppenheim and Willsky, "Signals and Systems", 1983. It states that a system is "any process that results in the transformation of signals." "Thus, a system has an input signal and an output signal which is related to the input through the system transformation". So a system is one where for two scalar signals x(t) and y(t), and a system h, h will transform x(t) into y(t) such that y(t) = h(x(t), t) depends only on the value of x over all time, on the value of t and on the properties of h. Take two multipliers a_1 and a_2, and two input signals x_1 and x_2. Generate an input signal equal to x(t) = a_1*x_1(t) + a_2*x_2(t) A system h is linear in this sense if and only if y(t) = h(x(t), t) = a_1*h(x_1(t), t) + a_2*h(x_2(t), t). Linear time invariant systems (i.e. a system h where y(t-a) = h(x(t-a), t) iff y(t) = h(x(t), t)) are commutative -- one finds that any linear time invariant system can be described as a convolution operation, then one finds that convolution operations are commutative, and viola! one has a proof. Oppenheim has, I believe, a proof. I believe that time-invariance is not necessary, but I don't know and I'm too lazy to look it up or prove it at the moment. Nonlinear systems are, in general, not commutative. For instance the (nonlinear) system h_1(x(t), t) = x(t)^2 doesn't commute with the (linear) system h_2(x(t), t) = 42*x(t) -- applying h_1 first yields y = 42*x^2, where applying it second yields y = 1764*x^2, so they clearly aren't equal. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
kiki wrote:
>Could you please help me understand better by providing some deep thoughts >on why linear systems are commutative? > >If T1 and T2 are linear systems, then y1=T2(T1(x)) and y2=T1(T2(x)) > >y1 and y2 are the same. > >After seeing some examples of non-linear system and linear systems. I got >convinced that for non-linear system this property does not hold. > >But any deeper thinking? Proof? >
I thought this would cause confusion amongst the mathematicians. The OP is referring to systems theory as covered in electrical engineering, I believe. If I recall correctly from over twenty years ago when I had to work with these things, let I be either the nonnegative reals or the natural numbers. A linear system is a linear map from R^I to R^I. As another poster has pointed out, you may need time-invariance for commutativity. That is, letting L_t be the map such that [L_t (x)] (s) = x(t+s) for all s in I, T and L_t commute for all nonnegative t. (I may be messing this definition up a little.) Signal processing always struck me as applied functional analysis. -- Stephen J. Herschkorn herschko@rutcor.rutgers.edu
"Stephen J. Herschkorn" <herschko@rutcor.rutgers.edu> wrote in message
news:fHcfd.14194$bz4.1975817@news4.srv.hcvlny.cv.net...
Functional analysis always struck me as abstract signal processing. :-)
Tim Wescott wrote:
> has a proof. Oppenheim has, I believe, a proof. I believe that > time-invariance is not necessary, but I don't know and I'm too lazy to > look it up or prove it at the moment.
News flash (well, news to me at least): Time invariance _is_ necessary. If you have a signal x(t) = 1, h_1(x, t) = x*sin(w*t), h_2(x, t) = x convolve e^(-w*t) (i.e. a low-pass filter), then cascading with h_1 first gives you a delayed, attenuated sine wave, where h_2 first gives you just the sine wave. The commutative property also won't hold for MIMO systems, but I'll leave counter examples as an exercise for the reader. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"kiki" <lunaliu3@yahoo.com> wrote in message news:<cljh80$btq$1@news.Stanford.EDU>...
Given: T1(x) = m1*x + b1 T2(x) = m2*x + b2 Then: T2(T1(x)) = m2 * (m1*x+b1) + b2 = m2*m1*x + m2*b1 + b2 T1(T2(x)) = m1 * (m2*x+b2) + b1 = m1*m2*x + m1*b2 + b1 Thus T2(T1(x)) not equal T1(T2(x)) for linear systems
