ez-kit adsp 21364 problem: Can't set AD-21xxx in new session
Started by Jake January 10, 2006
Hi
I just got an EZ-kit from Analog Devices (ADSP-21364).
When I start VisualDSP for the first time a
session window shows up. The manual states that I should select "EZ-kit LITE
(ADSP-21xxx)"
as debug target but I can't find it in the drop-down list. If I click the
"Show all targets and platforms"
I see "EZ-kit LITE (ADSP-21xxx)" in the drop-down list but it is in grey and
I can't click it.
How do I solve this?
Thank you.
"Jake" <nospam@yabadabadoo.com> wrote in message
news:43c4039d$0$78280$157c6196@dreader1.cybercity.dk...
> Hi > > I just got an EZ-kit from Analog Devices (ADSP-21364). > > When I start VisualDSP for the first time a > session window shows up. The manual states that I should select "EZ-kit > LITE (ADSP-21xxx)" > as debug target but I can't find it in the drop-down list. If I click the > "Show all targets and platforms" > I see "EZ-kit LITE (ADSP-21xxx)" in the drop-down list but it is in grey > and > I can't click it. > > How do I solve this? > > Thank you.
Hi, Did you install the software that comes along with the kit? Which version is it? You could try also installing the latest version (4.0) with the latest updata (Dic 05) too. Also, are you starting VisualDSP with the kit powered and already connected to the PC via USB? Regards, JaaC
Yes
VisualDSP++ 4.0 Product Version: 4.0.4.0 IDDE version: 6.5.0.1 Build date: Oct 19, 2005
>You could try also installing the latest version (4.0) with the latest > updata (Dic 05) too.
I followed the step-by-step instructions in the manual. The 2nd step is to download updates, so I did that already.
>Also, are you starting VisualDSP with the kit powered > and already connected to the PC via USB?
Yes
Never mind ...I solved it ...Thanks for the quick reply though :o)
news:43c4b43a$0$67264$157c6196@dreader2.cybercity.dk...
> >> Did you install the software that comes along with the kit? > Yes > >>Which version is it? > > VisualDSP++ 4.0 > Product Version: 4.0.4.0 > IDDE version: 6.5.0.1 > Build date: Oct 19, 2005 > > > >>You could try also installing the latest version (4.0) with the latest >> updata (Dic 05) too. > > I followed the step-by-step instructions in the manual. The 2nd step is > to download updates, so I did that already. > > > >>Also, are you starting VisualDSP with the kit powered >> and already connected to the PC via USB? > > Yes
So, everything seems to be OK. You could try asking ADI DSP support for some help. As far as I recall, the contact address is dsp.support@analog.com. It can be found on the website, anyway. Good luck, JaaC
news:43c511f9$0$67262$157c6196@dreader2.cybercity.dk...
Jack: How did you solve it? Maybe someone else might find it useful.... JaaC
