Hi I am using the TI DSP eZdspf2812 DSP as a waveform generator. It is interfaced with a microcontroller. Basically the DSP acts as an encoder, ie it accepts a finite number of bits (1s & 0s) from the microcontroller and generates a waveform corresponding to the bits. Is the GPIO good for this interface between the DSP & microcontroller? Also the waveform goes to a D/A converter. Is it better to use the McBSP or the SPI for outputting the waveform? Thanks. Vikram
SPI or McBSP for Waveform Generator( TI dsp F2812)
Started by ●January 10, 2006
Reply by ●January 11, 20062006-01-11
"vickykulkarni" <vickykulkarni@hotmail.com> wrote in message news:UoydnTYEJ7pWq1nenZ2dnUVZ_sadnZ2d@giganews.com...> Hi > > I am using the TI DSP eZdspf2812 DSP as a waveform generator. It is > interfaced with a microcontroller. Basically the DSP acts as an encoder, > ie it accepts a finite number of bits (1s & 0s) from the microcontroller > and generates a waveform corresponding to the bits. Is the GPIO good for > this interface between the DSP & microcontroller?Why not to use one of the PWM outputs?> Also the waveform goes to a D/A converter. Is it better to use the McBSP > or the SPI for outputting the waveform?It all depends on the interface you have for your DAC chip. Either one could work.
