Hi I'm new to DSP and i'm doing a project on simulation of Digital Beamforming. I want to know how to get started with this. These are the objectives of the project : 1: To receive the RF signal, process and digitize the signal, and generate multiple receive beams. 2: To incorporate variable number of array elements and beams 3: To steer the generated beams in specific directions 4: To restrict sidelobe levels as sepecified please help me on this. I'm a computer science student. what are the steps to be followed in doing this. How can i get started. help me.
simulation of Digital BeamForming
Started by ●January 11, 2006
Reply by ●January 11, 20062006-01-11
ravirevolt wrote:> Hi I'm new to DSP and i'm doing a project on simulation of Digital > Beamforming. I want to know how to get started with this. These are the > objectives of the project : > 1: To receive the RF signal, process and digitize the signal, and generate > multiple receive beams. > 2: To incorporate variable number of array elements and beams > 3: To steer the generated beams in specific directions > 4: To restrict sidelobe levels as sepecified > please help me on this. I'm a computer science student. what are the steps > to be followed in doing this. How can i get started. help me.I don't understand -- does step 1 mean that you have to actually work with a real signal? Or are *all* of the above steps to be simulated by software? Also, digitize an *RF* signal? I really doubt it (the frequency is just too high) If we're talking 100% simulation, you have to start by setting up a function of space-time corresponding to a moving wave -- in the one- dimensional case, we're talking about a sin (w*t - l*x) kind of function. In 2- or 3-dimensional space, you have to generalize it. Then, simply "sample" the signal at the right points (by taking the value of the function at the given time and at the given points in space) -- after that, you're all set; there's a lot of design of the beamforming parameters to be done (to accomplish step 3 and 4, at least). HTH, Carlos --
"Carlos Moreno" <moreno_at_mochima_dot_com@mailinator.com> wrote in message news:rS6xf.68040$2O3.1269092@wagner.videotron.net...> ravirevolt wrote: >> Hi I'm new to DSP and i'm doing a project on simulation of Digital >> Beamforming. I want to know how to get started with this. These are the >> objectives of the project : >> 1: To receive the RF signal, process and digitize the signal, and >> generate >> multiple receive beams. >> 2: To incorporate variable number of array elements and beams >> 3: To steer the generated beams in specific directions >> 4: To restrict sidelobe levels as sepecified >> please help me on this. I'm a computer science student. what are the >> steps >> to be followed in doing this. How can i get started. help me. > > I don't understand -- does step 1 mean that you have to actually work > with a real signal? Or are *all* of the above steps to be simulated > by software? Also, digitize an *RF* signal? I really doubt it (the > frequency is just too high) > > If we're talking 100% simulation, you have to start by setting up a > function of space-time corresponding to a moving wave -- in the one- > dimensional case, we're talking about a sin (w*t - l*x) kind of > function. In 2- or 3-dimensional space, you have to generalize it. > > Then, simply "sample" the signal at the right points (by taking the > value of the function at the given time and at the given points in > space) -- after that, you're all set; there's a lot of design of > the beamforming parameters to be done (to accomplish step 3 and 4, > at least). > > HTH, > > CarlosWhat Carlos says. Basically, if your sidelobe spec allows it you will probably get away with assuming point isotropic radiators, ignoring polarisation and mutual coupling and looking only at regularly spaced linear arrays of elements - this ought to significantly simplify your problem and you can always complicate it later if you want. You also need signal center frequency and bandwidth so you can do an adequate job of representing the sampled baseband component before messing it up in an imperfect digital beam former. You might find that building an analytical model will give you a good initial insight , it should also give you a nice tool for deciding what your minimum element spacing should be and for plotting 'ideal' patterns to compare your digital beamformer patterns against. Best of Luck - Mike P.S. If you make all of your combinatorial logic delay based (ensure that any interpolation is linear phase shift with frequency over the full bandwidth occupied by any of your signals ) you may end up with a computationally expensive model but it's so much simpler to work out what's going on.
