i've done my sampling like this is it correct ?
i'm sampling a 3GHz signal;
design for 8 bit sample
double array[256]; //8 bit so
double amplitude=100;
double frequency=3000000000;
for(int i=0;i<256;i++)
array[i]=amplitude*sin(2*PI*frequency*i/(2*3000000000));
dc.setpixel(i,array[i],RGB(255,0,0));
plz guide me and explain if i'm wrong
sampling theorem
Started by ●January 12, 2006
Reply by ●January 12, 20062006-01-12
"ravirevolt" <ravirevolt@yahoo.co.in> wrote in message news:VdCdnSBiBPjsO1veRVn-vA@giganews.com...> > i've done my sampling like this is it correct ? > i'm sampling a 3GHz signal; > design for 8 bit sample > > double array[256]; //8 bit so > double amplitude=100; > double frequency=3000000000; > for(int i=0;i<256;i++) > { > array[i]=amplitude*sin(2*PI*frequency*i/(2*3000000000)); > dc.setpixel(i,array[i],RGB(255,0,0)); > } > > plz guide me and explain if i'm wrongSince you haven't given too much background information, I'll just comment on what you've shown us... What does 8 bit samples have to do with double array[256]? It appears you are doing a simulation of some kind and it appears you have double precision arithmetic. If you want 8 bit samples, you have to convert your array[i] to say short ints (but that's usually 16 bits), so you'll need to do more conversions to ensure they have only 8 bit data in them. You sampling frequency fs here is 2*fin where fin is your sinusoid'd frequency. I'd recommend you use fs = 4*fin or higher for your simulation purposes (as well as in a real system). The Nyquist theorem mandates an fs > 2*fin. Also, your time index (i) in your sine computation should be different from your loop index. Cheers Bhaskar
"ravirevolt" <ravirevolt@yahoo.co.in> wrote in message news:VdCdnSBiBPjsO1veRVn-vA@giganews.com...> > i've done my sampling like this is it correct ?Is this associated with your previous post about simulating a digital beamformer?> i'm sampling a 3GHz signal;is that your signal bandwidth or signal center frequency?> design for 8 bit sample > > double array[256]; //8 bit sohave you reserved space for a 256 element double precision vector called array here? Why not give it a descriptive name and insert a comment that helps you remember what you are physically representing?> double amplitude=100;You seem to have arbitrarily set the peak amplitude = 100. A comment as to why you did this might help you interpret your code at a later date.> double frequency=3000000000;> for(int i=0;i<256;i++) > { > array[i]=amplitude*sin(2*PI*frequency*i/(2*3000000000));now load up 256 elements with something very close to zero ? sign will alternate but maybe not that reliably, why are you doing this? What does your i index represent?> dc.setpixel(i,array[i],RGB(255,0,0));produce a short monochrome line on a display? what happens if array[2] is -ve by the way?> } > > plz guide me and explain if i'm wrongHow can we? - you don't say what you are trying to do. Best of Luck - Mike
