Hello Everybody, I am a novice in Signal Processing field. I saw few messages on Interpolation. I have a similar doubt. I have a complex chirp signal. And I wanna interpolate this signal to get intermediate values.I tried to interpolate using an FIR filter with coefficients calculated using sinc interpolation but i could nt get the desired reult even with a large filter length. I dont know how to design an FIR filter for this problem? Rose
FIR filter
Started by ●January 12, 2006
Reply by ●January 12, 20062006-01-12
<rosy27@gmail.com> wrote in message news:1137100662.292055.259180@g44g2000cwa.googlegroups.com...> Hello Everybody, > > I am a novice in Signal Processing field. I saw few messages on > Interpolation. I have a similar doubt. I have a complex chirp signal. > And I wanna interpolate this signal to get intermediate values.I tried > to interpolate using an FIR filter with coefficients calculated using > sinc interpolation but i could nt get the desired reult even with a > large filter length. I dont know how to design an FIR filter for this > problem? > > Rose >The details of the filter design may be the least of your worries. What you need to do is stuff zeros in between the existing samples and then use a filter. Is that your problem? i.e. not doing the zero stuffing first? Somehow you need to get the sample rate up to affect interpolation. So, adding zero-valued samples in between the existing samples does that. Then, filtering will make the zeros into non-zero values - hence interpolation. Note that the interpolating filter will have coefficients that operate on all the samples, including the zero-valued ones. In other words, the filter will have a unit delays equal to the new sample interval. A really simple 2X interpolator filter is [1/2 1 1/2]. Here's how it works: Original sequence to interpolate: [1 2 3 4 5 6 5 6 5 6 5 4 3 2 1] Add zeros to increase the sample rate: [1 0 2 0 3 0 4 0 5 0 6 0 5 0 6 0 5 0 6 0 5 0 4 0 3 0 2 0 1] Convolve with the filter from above to get the interpolated sequence: [0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 5.5 5 5.5 6 5.5 6 5.5 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5] Once you have this well in mind, then consider half-band filters for the same purpose. Fred Fred
Reply by ●January 13, 20062006-01-13
> A really simple 2X interpolator filter is [1/2 1 1/2]. Here's how it > works:Hi, i have the same problem: What about a 2.1X interpolator? Really I don't understand the relation between the interpolator factor and filter's coefficent. Can you tell me more? Thanks in advance, Emiliano.
Hi, In a signal processing practice the problem formulates as the following: "how to change sampling rate preserving spectral data". For example, if current sampling is 16 kHz, target rate is 32kHz and the input vector is a chirp signal 0-8kHz then the output should be a chirp 0-8kHz (i.e. half-band reps to 32kHz sampling rate) having twise more samples than original. Note, if above is a downsampling (16 -> 8) problem, then the output is a chirp 0-4kHz (all above 4kHz should be zero). Looking at a FIR/IRR equation one can easily cath that a feeding of a single sample at the filter input derives a single output sample. So, there is no interpolation. Known fact is that the insertion of n-zeros between samples has a spectrum reflection effect in a frequency domain ("inverse" situation takes place in a samples removal case). That is why you need a filter - to remove unnecessary spectrum components. The length determines how flat is your filter. Cutoff position (normalized) is dependent on interp. factor 2x - .5, 3x - .3 ... Using zeros inserting/removing + filtering you can perform up/down-sampling at any integer factor. (2.1x times interpolation = 21 times up and 10 times down) For a fractional factors one have to use big integer multipliers and spline interpolation is more preferable this case, but it has a drawbacks in a frequency domain. Dmitry
