Hi, I am new in the dsp domain and I want to design a moving average filter which separate the input signal in different signals based on different frequency bands. My input signal is sampled with 8000. I defined different frequency bands and a center frequency. I would like to apply the filter to the input signal and get the lowpass filter and after I obtained the first signal to substract from the original signal and get the next lowpass filter for the next band. If anyone can help me please reply. Thanks, AK
Moving average filter
Started by ●January 13, 2006
Reply by ●January 14, 20062006-01-14
"AK13" <arpi_ka@yahoo.com> wrote in message news:1137185197.471794.67000@g49g2000cwa.googlegroups.com...> Hi, > > I am new in the dsp domain and I want to design a moving average filter > which separate the input signal in different signals based on different > frequency bands. > My input signal is sampled with 8000. I defined different frequency > bands and a center frequency. I would like to apply the filter to the > input signal and get the lowpass filter and after I obtained the first > signal to substract from the original signal and get the next lowpass > filter for the next band. > If anyone can help me please reply. >look for " half-band decimation" or similar to start with ; you should soon find lots of cross-references to different techniques and comparisons between them. Best of Luck - Mike
AK13 wrote:> Hi, > > I am new in the dsp domain and I want to design a moving average filter > which separate the input signal in different signals based on different > frequency bands. > My input signal is sampled with 8000. I defined different frequency > bands and a center frequency. I would like to apply the filter to the > input signal and get the lowpass filter and after I obtained the first > signal to substract from the original signal and get the next lowpass > filter for the next band. > If anyone can help me please reply.What you describe is sensible - remember to use linear-phase lowpass filters in order to implement the paralell subtraction scheme. Which part do you need help with?
Reply by ●January 16, 20062006-01-16
Andor wrote:> AK13 wrote: > > > Hi, > > > > I am new in the dsp domain and I want to design a moving average filter > > which separate the input signal in different signals based on different > > frequency bands. > > My input signal is sampled with 8000. I defined different frequency > > bands and a center frequency. I would like to apply the filter to the > > input signal and get the lowpass filter and after I obtained the first > > signal to substract from the original signal and get the next lowpass > > filter for the next band. > > If anyone can help me please reply. > > What you describe is sensible - remember to use linear-phase lowpass > filters in order to implement the paralell subtraction scheme. Which > part do you need help with?With both part. My problem is I don't know how to choose the right parameters for the calculations.If I use filtering in the time domain then how can specify frequency domain? How can I calculate from frequency range the number of points for moving average which give me the correct signal. My signal is encoded with ulaw. What is the paralell substraction scheme? What about the half-band decimation? Thanks, AK
AK13 wrote:> Andor wrote: > > AK13 wrote: > > > > > Hi, > > > > > > I am new in the dsp domain and I want to design a moving average filter > > > which separate the input signal in different signals based on different > > > frequency bands. > > > My input signal is sampled with 8000. I defined different frequency > > > bands and a center frequency. I would like to apply the filter to the > > > input signal and get the lowpass filter and after I obtained the first > > > signal to substract from the original signal and get the next lowpass > > > filter for the next band. > > > If anyone can help me please reply. > > > > What you describe is sensible - remember to use linear-phase lowpass > > filters in order to implement the paralell subtraction scheme. Which > > part do you need help with? > > With both part. My problem is I don't know how to choose the right > parameters for the calculations.If I use filtering in the time domain > then how can specify frequency domain? How can I calculate from > frequency range the number of points for moving average which give me > the correct signal.Well, you need to specify how many bands you want and at what center frequencies the bands are placed (you have done that already). Now you have to design the linear-phase FIR coefficients (which includes determining how many coefficients you need to fullfill your filtering requirements). To do this you need some kind of filter coefficient computation program. Scilab / Octave are available for free and should include what you need. Or do you have access to Matlab? There are many commercial filter design programs available, have a look in http://www.dspguru.com/> My signal is encoded with ulaw.This is usually decoded by the hardware, don't worry about it.> What is the paralell substraction scheme?That's a way to implement a filter bank using several linear-phase lowpass filters. Generate the highest band by subtracting the first lowpass output from the original (delayed) signal, then generate the second highest band by subtracting the the second lowpass filter output from the first, etc. It's what you described above. If you draw a schematic, you'll see a whole bunch of lowpass filters in parallel.> What about the half-band decimation?That depends on whether the bands are scaled by a factor of two. Regards, Andor
Reply by ●January 17, 20062006-01-17
If I use the moving average filter and subtraction then can I obtain the desired frequency bands? How I should choose the number of average. Thanks, AK
AK13 wrote:> If I use the moving average filter and subtraction then can I obtain > the desired frequency bands? How I should choose the number of average. > > Thanks, > AKProbably not. The moving average filter does not have very good out of band rejection. Its frequency response looks like sinx/x which has an out of band peak that is only 13 dB down. John
Reply by ●January 18, 20062006-01-18
What is the best method and simple for reshaping the signal? If I make the moving average and reshape the signal then I can approximate the singal for the band and at the substraction I will get better result then can I use this method for separate the bands? For each band I need n samples in a period to detect a signal in this band. How can I choose this sample times? (if for 200 hz band I need 4 samples in a period to detect the signal and for 2000 I need 40 samples to detect the waveform then how do I choose this 4 samples? I take every 10 samples? Thanks. AK
Reply by ●January 19, 20062006-01-19
john wrote:> AK13 wrote: > > If I use the moving average filter and subtraction then can I obtain > > the desired frequency bands? How I should choose the number of average. > > > > Thanks, > > AK > > Probably not. The moving average filter does not have very good out of > band rejection. Its frequency response looks like sinx/x which has an > out of band peak that is only 13 dB down.You are thinking of the FIR filter with impulse response equal to [1 1 ... 1], right? I was thinking that the OP thought of "moving average" (MA) filters in the statistical processing terms, ie. MA = transversal filters, AR = recursive filters. That is, moving average filters are not constrained in their coefficients, just another term for FIR filters. As such, it makes perfect sense to construct a filter bank from FIR lowpass filters. Regards, Andor
