Hi All, I m working on DM642 DSP from TI . I would like to know as to how can i calculate the "time taken by a particular task/function". The CCS ver2.21 has the profiler in that,but,it takes hell lot of time(when using profiler,the CCS goes into Simulator MODE). Is there any other way around?. I have tried using DSP/BIOS object STS ,as specified in DSP/BIOS debugging tutorial.this particular object uses CLKgettime() function. Thanks MA Imran
Timing calculations
Started by ●July 22, 2004
Reply by ●July 22, 20042004-07-22
"MIA" <imran_akthar@hotmail.com> wrote in message news:b36ae06a.0407211928.ec1cbf@posting.google.com...> Hi All, > I m working on DM642 DSP from TI . > I would like to know as to how can i calculate the "time taken by a > particular task/function". > The CCS ver2.21 has the profiler in that,but,it takes hell lot oftime(when> using profiler,the CCS goes into Simulator MODE). > Is there any other way around?. > I have tried using DSP/BIOS object STS ,as specified in DSP/BIOS debugging > tutorial.this particular object uses CLKgettime() > function.You could use a 'scope and a spare output if you have one - set it high at the beginning of the function and low at the end. Leon
Reply by ●October 6, 20052005-10-06
