Hi I posted a similar question a few days ago and got a good answer. But there is still one thing I don`t understand, maybe anybody could help me again. My problem is still the segID. In some manuals TI writes the segID could be an integer or the memory segment name which you have defined in the DSP/BIOS Configuration Tool. Before you can use the segID identifier which is defined in the DSP/BIOS you have to declare the Heap lable for example like this: ////////////////////////////////////////////////////////////////////////// extern int IRAM_HEAP void myfilter(void) { int *coeff; coeff = MEM_alloc(IRAM_HEAP,128,0); .. .. .. MEM_free(IRAM_HEAP,coeff,128); } //////////////////////////////////////////////////////////////////////// But TI says instate of the section lable you could also use an integer. These would be better for my application but how can I specify which memory section is linked to which integer. SDRAM_HEAB IPRAM_HEAB // for example these are the 3 available section in the DSP/BIOS IDRAM_HEAB ////////////////////seperate file///////////////////////////////////////////////// void* newMEM(int sec, int size, int align) { void* ret; ret = MEM_calloc(sec,size,align); if( MEM_ILLEGAL == ret ) { while(1) ; } return ret; } /////////////////////////////seperate file///////////////////////// #include "sections.h" void filter1(void) { int *coeff; int nsize; size=128; coeff = newMEM(DATAMEM_INTERNAL, nsize, 0); .. .. .. } //////////////////////////////////sections.h Header ///////////////////////// enum MemSection { MEM_EXTERNAL PROGMEM_INTERNAL DATAMEM_INTERNAL }; I know normaly I could declare the section lables in the sections.h file but in my case its impossible. And now my question: how can I tell the BIOS that SDRAM_HEAB = 0, IPRAM_HEAB = 1 and IDRAM_HEAB = 2.
MEM_Alloc TI
Started by ●January 19, 2006
