Hi, I was wondering if for an underdetermined system the Matlab mldivide (equivalent to \) function will retrurn the minimum norm solution, or if the returned solution is constrained in another way or if the solution has no particular properties beyond satisfying the set of equations ? The matlab help page doesn't help me. http://www.mathworks.com/access/helpdesk/help/techdoc/ref/mldivide.html Thanks, NL
Matlab mldivide, minimum norm ?
Started by ●January 19, 2006
Reply by ●January 19, 20062006-01-19
"NewLine" <umts_remove_all_this@skynet.be> wrote in message news:43cffb7d$0$4768$ba620e4c@news.skynet.be...> Hi, > > I was wondering if for an underdetermined system the Matlab mldivide > (equivalent to \) function will retrurn the minimum norm solution, or if > the returned solution is constrained in another way or if the solution has > no particular properties beyond satisfying the set of equations ? > > The matlab help page doesn't help me. > > http://www.mathworks.com/access/helpdesk/help/techdoc/ref/mldivide.html >You could have a look here - http://people.csail.mit.edu/nati/mmmf/code.html Best of luck - Mike
Reply by ●January 20, 20062006-01-20
NewLine wrote:> Hi, > > I was wondering if for an underdetermined system the Matlab mldivide > (equivalent to \) function will retrurn the minimum norm solution, or if the > returned solution is constrained in another way or if the solution has no > particular properties beyond satisfying the set of equations ? > > The matlab help page doesn't help me. > > http://www.mathworks.com/access/helpdesk/help/techdoc/ref/mldivide.html>From the above link:"If A is an m-by-n matrix with m ~= n and B is a column vector with m components, or a matrix with several such columns, then X = A\B is the solution in the least squares sense to the under- or overdetermined system of equations AX = B."
>> Hi, >> >> I was wondering if for an underdetermined system the Matlab mldivide >> (equivalent to \) function will retrurn the minimum norm solution, or if >> the >> returned solution is constrained in another way or if the solution has no >> particular properties beyond satisfying the set of equations ? >> >> The matlab help page doesn't help me. >> >> http://www.mathworks.com/access/helpdesk/help/techdoc/ref/mldivide.html > >>From the above link: > > "If A is an m-by-n matrix with m ~= n and B is a column vector with m > components, or a matrix with several such columns, then X = A\B is the > solution in the least squares sense to the under- or overdetermined > system of equations AX = B." >I understand the least squares in an overdetermined system. How is a least squares solution defined for an underdetermined system ? Any solution will satisfy AX-B = 0.
Reply by ●January 21, 20062006-01-21
NewLine wrote: ...> I understand the least squares in an overdetermined system. How is a least > squares solution defined for an underdetermined system ? > Any solution will satisfy AX-B = 0.Perhaps the X with least squares norm is chosen? This is usually done in linear least squares when the design matrix does not have full rank.
