Hi all, I would like to know "the" right method to analytically calculate the Probability Density Function (PDF) of the output of a FIR filter whose input PDF is not gaussian (the indicator function for instance)... I learnt that when i was a student (long time ago) and i can't remember the way to make such calculation... :( Can anyone help ? Thanx in advance. A.Herbert
Statistics of linearly filtered signal
Started by ●July 21, 2004
Reply by ●July 21, 20042004-07-21
Arthur Herbert wrote:> Hi all, > I would like to know "the" right method to analytically calculate the > Probability Density Function (PDF) of the output of a FIR filter whose > input PDF is not gaussian (the indicator function for instance)... > I learnt that when i was a student (long time ago) and i can't remember > the way to make such calculation... :( > Can anyone help ? > Thanx in advance. > A.HerbertI don't think there is a short answer - since the output of the filter is just the weighted output of all the samples, if you have white noise you can just use basic statistical theory to figure it out. If the PDF of the input is well-enough behaved, and if you have enough samples to significantly span it's autocorrelation function then you can take refuge in the central limit theorem and claim that the output is Gaussian with mean and variance determined by the filter properties and the mean and variance of the input signal. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●August 5, 20042004-08-05
Arthur Herbert wrote:> Hi all, > I would like to know "the" right method to analytically calculate the > Probability Density Function (PDF) of the output of a FIR filter whose > input PDF is not gaussian (the indicator function for instance)...You need two facts: 1. The pdf f of the sum of two random variables X_1 and X_2 (with pdf f_1 and f_2) is the convolution: f = f_1 * f_2. 2. If X has pdf f_X, then the random variable Y = a X (a =/= 0) has pdf f_Y(y) = 1/|a| f_X(y/a) Therefore if the input is i.i.d. with pdf f, then the FIR output has pdf f_FIR(x) = \convolution_{k=0}^{N-1} 1/|a_k| f(x/a_k) Alternatively, you can calculate the inverse Fourier transform of the N-th power of the characteristic function of the pdf f. Regards, Andor
Arthur Herbert <herbert.arthur@caramail.com> writes:> Hi all, > I would like to know "the" right method to analytically calculate the > Probability Density Function (PDF) of the output of a FIR filter whose > input PDF is not gaussian (the indicator function for instance)... > I learnt that when i was a student (long time ago) and i can't > remember the way to make such calculation... :( > Can anyone help ? > Thanx in advance. > A.HerbertIf the input samples are independent, then the output pdf is the convolution of the input pdf's. The coefficients scale the input pdf's. -- % Randy Yates % "Maybe one day I'll feel her cold embrace, %% Fuquay-Varina, NC % and kiss her interface, %%% 919-577-9882 % til then, I'll leave her alone." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
"Andor Bariska" <an2or@nospam.net> wrote in message news:4111e4cd$1@pfaff2.ethz.ch...> > 1. The pdf f of the sum of two random variables X_1 and X_2 (with pdf > f_1 and f_2) is the convolution: > > f = f_1 * f_2.As Randy Yates noted in his response, this convolution formula applies when the random variables are independent. More generally, the pdf of the sum is given by the integral integral from -infinity to +infinity f(x, z-x) dx where f(x, y) is the joint pdf of the two variables. This reduces to integral from -infinity to +infinity f_1(x).f_2(z-x) dx = f_1 * f_2 when the random variables are independent because then the joint pdf factors into the product of the pdfs of X_1 and X_2.
