Hi, I'm trying to filter out heavy white and pink noise in a wav file to figure out the frequency of a repeating piano note. I'm kind of a noob. I'm working with Matlab and I'm just not to sure what kind of filter I should use... If anyone could give me any brief ideas I'd greatly apreciate it. Thanks in advance, Frank
Filtering out pink & white noise
Started by ●January 19, 2006
Reply by ●January 20, 20062006-01-20
Francois Maillet wrote:> Hi, > > I'm trying to filter out heavy white and pink noise in a wav file to figure > out the frequency of a repeating piano note. > > I'm kind of a noob. I'm working with Matlab and I'm just not to sure what > kind of filter I should use... > > > If anyone could give me any brief ideas I'd greatly apreciate it. > > > Thanks in advance, > > Franka narrow band bandpass filter... but you have to know or guess what the answer is.... put the filter on the frequency where you think the tone is..... if you have no idea where the tone is then you need to slowly sweep the narrow filter until you find the tone...so it helps if you have an a priori idea of where to look .... Once you find the tone and if it is stable in frequency, you can continue to narrow the filter and remove more noise.....the limit being determined by the frequency stability of the tone.. Mark Mark
