Thanks Bill, that would be interesting to see. I don't have PSP myself. I know that various image editing programs have plugins available that allow deblocking based on user interaction and tunable parameters. I am mainly seeking comparisons with deblocking filters that do not require this sort of fine-tuning, as they are not suitable for video applications. The Pegasus decompressor falls into this category, although I am trying to figure out why their two products are giving different results (see above discussion with Jack). But I'd still be very interested to see any comparisons, whether user input is required or not, for reference purposes. On the demo page I posted comparisons of the same image across a wide range of compression ratios, because it is just as important that the algorithm not degrade high-quality images as it is that it deblock more highly compressed ones. Thanks in advance for any comparisons you can provide. John
Deblocking filter for JPEG/digital video
Started by ●January 21, 2006
Reply by ●January 24, 20062006-01-24
Hi M, Understood about the ringing -- my goal was to removing the blocking, not the ringing, which is an artifact of any Fourier technique because of the Gibbs phenomenon. However, having said that, I am also looking at using some similar tricks to work on the ringing problem too. (That's for another day.) I understand that it is difficult to create an objective test, because the blocking phenomenon is objectionable, visually, because the discontinuities are correlated into edges, and the human visual system is very good at detecting edges. As you note, a simple measure like SNR, that does not take into account this coherence effect, is not very useful. Of course, I do have an objective way to quantify the average degree of blocking artifact across an image, because the UnBlock algorithm uses it, and then removes it. :) But I can hardly apply this metric to images processed by other algorithms, because UnBlock will always come out as being perfect, which is hardly a useful comparison at all. I guess the answer you are giving me is that, no, there are no agreed objective tests of deblocking efficiency. I would be interested in knowing of the other deblocking algorithms that you have seen and implemented, if they are publicly demonstrated, anyway. I know that Pegasus have boasted the best decompressors over the years, and to their credit they have put their software out there to be put to the test. I guess I am looking to test against algorithms that have been implemented and can be applied by anyone to any image (even if the details of how they work have not been released), rather than academic suggestions that have only been tested by the authors on their own selected images. Thanks again for your comments, John
Reply by ●January 25, 20062006-01-25
John Costella wrote:> All but one of the papers on that site were no longer there, but the > one that was had a couple of sample grayscale results. They did look > quite good at low resolution, although on magnification remnant > blocking artifacts remained.It does leaves some patchiness on what should be smooth gradients, most post processing filters don't completely reconstruct linear gradients where possible ... it can prevent some blurring, but overall I would call it a fault in their design. All in all I still think it looks better though, especially on something like Lena. Your algorithm has the tendency to cause stair casing on hard edges. It also does leave some blocking in place, mostly along vertical lines for some reason. I also think the algorithm is quite elegant, slow but straightforward and derived from first principles rather than ad-hoc like most post processing filters. Marco
John Costella wrote:> Hi M, > > Understood about the ringing -- my goal was to removing the blocking, > not the ringing, which is an artifact of any Fourier technique because > of the Gibbs phenomenon. However, having said that, I am also looking > at using some similar tricks to work on the ringing problem too. > (That's for another day.) > > I understand that it is difficult to create an objective test, because > the blocking phenomenon is objectionable, visually, because the > discontinuities are correlated into edges, and the human visual system > is very good at detecting edges. As you note, a simple measure like > SNR, that does not take into account this coherence effect, is not very > useful. > > Of course, I do have an objective way to quantify the average degree of > blocking artifact across an image, because the UnBlock algorithm uses > it, and then removes it. :) But I can hardly apply this metric to > images processed by other algorithms, because UnBlock will always come > out as being perfect, which is hardly a useful comparison at all. > > I guess the answer you are giving me is that, no, there are no agreed > objective tests of deblocking efficiency. > > I would be interested in knowing of the other deblocking algorithms > that you have seen and implemented, if they are publicly demonstrated, > anyway. I know that Pegasus have boasted the best decompressors over > the years, and to their credit they have put their software out there > to be put to the test. I guess I am looking to test against algorithms > that have been implemented and can be applied by anyone to any image > (even if the details of how they work have not been released), rather > than academic suggestions that have only been tested by the authors on > their own selected images. > > Thanks again for your comments, > John >Granted that PSNR may not be the best objective measure, I would like to see figures about achievable compression ratios for same quality, ie JPEGcompress+JPEGdecompress vs. compress+decompress+unblock. -- Michel Bardiaux R&D Director T +32 [0] 2 790 29 41 F +32 [0] 2 790 29 02 E mailto:mbardiaux@mediaxim.be Mediaxim NV/SA Vorstlaan 191 Boulevard du Souverain Brussel 1160 Bruxelles http://www.mediaxim.com/
John, Yes, I checked and the JPEG Wizard product is a few code versions back. It is scheduled for an update later this year. Sorry I mislead you there. It does show lossless JPEG crop, lossless JPEG hue/tint/brighten/contrast and 'lossless' JPEG recompression however. The Minerva code, with the 'enhanced decompression' flag set is close to our latest code however, and you are to be applauded for getting better results than this, as it is pretty doggone good. JPEG is less and less a focus here at Pegasus, for obvious reasons like JPEG 2000, so it has been a while since we looked at JPEG decompression and deblocking. However, some time ago we looked around and did find some superior deblocking schemes, in some cases, than our own, but in our judgment they were too computationally expensive to be commercially viable. If speed is not an issue then JPEG 2000 will provide superior compression results with less artifacts everytime anyway. So, all the computations in the world is still not going to produce wavelet quality to DCT compressed images at some threshold of compression ratio. Our deblocking is meant to squeeze out a few percent of quality when it matters (printing) with as little speed impact as possible. None of this should be taken to minimize your work or its importance. This is just where Pegasus is in its priorities at the moment. Artifact removal is very important research, as it results in enabling higher compression ratios if needed. Continued work in this area would be applicable to digital video, as you said (if made computationally acceptable), or applied to wavelet compressed images perhaps. Your results seem promising and certainly better than ours in some/most/all? cases. In extreme compression cases your edges seem to blur and ours do not, but I doubt that case is also not of commercial interest. Our artifacting is certainly more objectionable to the eye and your PSNR is slightly better in the couple of images we tried. Even with our in house smoothing algorithm, not released, your results seem slightly better. So, seems to be a nice bit of science. This is why we try to stay a very open and transparent image technology company. It is easy to test our algorithms for yourself, and hopefully glean ideas and improvements to our work. (The absolute latest code would be found in our PICTools RapidVUE development kit with the command source code sample.) And when you have a test program the members of this group can test we would enjoy seeing the computational effort you are applying to achieve these results. I am sure it would be interesting to understand the algorithmic complexity variance between your method and ours. Perhaps Pegasus can find a commercial use for your work? Good luck, jack -- http://www.jpg.com/ - Pegasus - The BETTER JPEG People! -- "John Costella" <jpcostella@hotmail.com> wrote in message news:1138147954.389198.208280@o13g2000cwo.googlegroups.com...> Hi Jack, > > My comparisons were based on the Minerva program, which I had > downloaded from pegasusimaging.com. You are right: the About box lists > it as Copyright 1996-2005, Version 1.0.0.155 for PIC version 2.00 > libraries, and the page http://www.pegasusimaging.com/jpegfeatures.htm > refers to it as your current "Pegasus imaging viewer". Apologies for > being cautious as to whether it represented your current technology. > > I have now downloaded JPEG Wizard 2, but it seems to do a much worse > job at deblocking than Minerva. Indeed, it only seems to apply > deblocking to very highly compressed images, and only then in selected > areas. I cannot find any option to turn on deblocking for less heavily > compressed images. Am I missing something? > > I do not see the chrominance smoothing option either, in either Minerva > or JPEG Wizard 2; could you guide me to it? > > In any case, the results from Minerva don't seem to be optimal. I have > compared them for the same test images as on the UnBlock demo page and > you can see from a side-by-side comparison that they fall short at all > compression ratios: > > http://www.assassinationscience.com/johncostella/unblock/pegasus-v-unblock.html > > I agree that the Pegasus decompressor does not introduce blurring or > distortion in its deblocking, but neither does UnBlock, and neither, I > assume, do other deblocking filters available. > > I will continue to play with JPEG Wizard 2, but so far I am hitting a > brick wall with it. > > Thanks for your help, > John >
In comp.compression John Costella <jpcostella@hotmail.com> wrote:> > Thanks Bill, that would be interesting to see. I don't have PSP myself. > > I know that various image editing programs have plugins available that > allow deblocking based on user interaction and tunable parameters.PSP is one of them. I used defaults: Normal Strength, Sharpness 50. The documentation says nothing about these parameters, nor did I find anything on the web recommending different settings. Here are the comparisons, offered without comment. The "ski" image is from an old Fuji digicam. The "twins" image is R rated nudes, saved from e-mail due to incredibly bad JPEG encoding, somewhat corrected here. http://cacreeks.com/unblock/
John Costella wrote:> Hi M, > > Understood about the ringing -- my goal was to removing the blocking, > not the ringing, which is an artifact of any Fourier technique because > of the Gibbs phenomenon. However, having said that, I am also looking > at using some similar tricks to work on the ringing problem too. > (That's for another day.) > > I understand that it is difficult to create an objective test, because > the blocking phenomenon is objectionable, visually, because the > discontinuities are correlated into edges, and the human visual system > is very good at detecting edges. As you note, a simple measure like > SNR, that does not take into account this coherence effect, is not very > useful. > > Of course, I do have an objective way to quantify the average degree of > blocking artifact across an image, because the UnBlock algorithm uses > it, and then removes it. :) But I can hardly apply this metric to > images processed by other algorithms, because UnBlock will always come > out as being perfect, which is hardly a useful comparison at all. > > I guess the answer you are giving me is that, no, there are no agreed > objective tests of deblocking efficiency. > > I would be interested in knowing of the other deblocking algorithms > that you have seen and implemented, if they are publicly demonstrated, > anyway. I know that Pegasus have boasted the best decompressors over > the years, and to their credit they have put their software out there > to be put to the test. I guess I am looking to test against algorithms > that have been implemented and can be applied by anyone to any image > (even if the details of how they work have not been released), rather > than academic suggestions that have only been tested by the authors on > their own selected images. > > Thanks again for your comments, > JohnI'll email you the one's I implemented, which were all from academic papers. Cheers! --M
Reply by ●January 28, 20062006-01-28
Hi Marco, I'd appreciate it if you could post some images somewhere (or send them to me) showing examples of the staircasing and vertical lines. UnBlock does not affect a linear gradient across a boundary (nor a parabolic one, for that matter). I'm not sure if you are saying that the other algorithm erroneously modifies such gradients, or whether you are talking about something more subtle. The UnBlock algorithm treats vertical and horizontal lines equally, but of course it analyzes the image before correcting it, so if there are many (true) vertical-line discontinuities in the your image (i.e. in the interiors of the blocks), it won't be as aggressive on the vertical block boundaries. I'd be interested to see your examples. Thanks again John
No worries, Jack. I applaud the way that Pegasus has put its claims out there for all to test, and your honesty in telling me that UnBlock out-performs your new patented but unreleased deblocking method (something I would have had no way of testing if you hadn't told me) says volumes about your company's integrity. I'm impressed. In terms of computational speed, the UnBlock algorithm is very fast. There are no transcendental functions, divisions, or multiplications involved, only integer additions and subtractions, and bitwise right-shifts. Only blocks bordering a boundary are used in its analysis and correction (except for a very fast global process at the end of the analysis pass). As I noted in an earlier posting, the deblocking analysis and correction takes only about twice as long per pixel as the colorspace conversion and chrominance upsampling, which is also done as fast as possible (well, as fast as I could think of), without the use of multiplications or divisions, similarly to the way the IJG code does it. The deblocking corrections are done in-place (or optionally to another image, without altering the original), with look-up tables and row buffers taking only a nominal number of kilobytes. The code is currently written in ANSI C, makes no assumptions about architecture, and pixel access is done by generalized macros that can be changed in the header file. (The Windows app on my website uses 32-bit COLORREF structures, but it can be changed via a #define switch to handle BGRBGR triples, etc.) The code itself is not too complex (the object file is 25 kB in VC6). Just some intelligent mathematics, as I am sure is also the case with much of Pegasus's code. :) I am sure that an assembler version for a specific architecture and pixel structure would squeeze out even more speed, because then register and pointer management can be optimized, etc. At the moment I haven't even optmized by unrolling the grayscale and color routines into different functions; there are grayscale/color switches all over the place. Even more cycles could be saved if the results of the analysis phase were saved in an image-sized buffer, because currently they are discarded and then recomputed all over again in the correction pass, although the speed gain would probably only be of the order of 20-30% (at the expense of an extra image-sized memory buffer). Right now I haven't decided what I'm going to do with the algorithm, the code, and the short scientific paper that describes and derives the relevant formulas. I'd be happy to hear from you privately (initially email me jpcostella@hotmail.com) if you think that it's something that has a degree of commercial potential, however minor that may now be. (I understand JPEG is now a mature technology, and no longer at the edge of research, but the algorithm is fast enough to play a role in video applications.) As far as JPEG 2000 is concerned, I don't know enough about it yet to comment. I have some ideas (in progress) as to how some of the same tricks used in UnBlock (plus a couple more) could be used, together with plain old JPEG, to address the fundamental weaknesses of a DCT approach like JPEG without needing to go to wavelet methods. Whether it pans out or not, I don't know; like UnBlock, I'll suck it and see. :) Thanks again, John
Thanks for those, Bill. The two images you've tested seem to suffer much worse from ringing artifacts than blocking, and so it's difficult to come to any conclusions. Definitely, for the twins image, the maximum PSP setting is doing a good job at removing a lot of the ringing -- but that's not what UnBlock addresses. I'll be addressing the ringing problem separately, so I'll defer a more complete discussion of it to then. If you have the chance, would you be able to process the following test images using PSP? http://www.assassinationscience.com/johncostella/unblock/before000.jpg http://www.assassinationscience.com/johncostella/unblock/before005.jpg http://www.assassinationscience.com/johncostella/unblock/before010.jpg http://www.assassinationscience.com/johncostella/unblock/before020.jpg That would give me something definite to compare some of the existing results against. Thanks again, John
