I apologize, I am a video signal processing newbie. I am using a NI 1410 board to capture images from an interlaced RS-170 video source. When the images are captured, the odd field is about 3% brighter than the even field. The noise is also higher in the odd field. Has anyone experienced this? Could it have something to do with the clamp timing? Is it possible that interference on the video cable could cause this since it's uniform across the entire field? The video is coming from an X-Ray machine so high voltages are present. The interference would basically would basically be at a rate of 30 hertz, if I'm not mistaken, since it is every other field. Thanks in advance, Mike
Interlaced video fields of unequal brightness
Started by ●January 25, 2006
Reply by ●January 25, 20062006-01-25
Mike wrote:> I apologize, I am a video signal processing newbie. > > I am using a NI 1410 board to capture images from an interlaced RS-170 > video source. When the images are captured, the odd field is about 3% > brighter than the even field. The noise is also higher in the odd > field. > > Has anyone experienced this? Could it have something to do with the > clamp timing? Is it possible that interference on the video cable > could cause this since it's uniform across the entire field? The video > is coming from an X-Ray machine so high voltages are present. The > interference would basically would basically be at a rate of 30 hertz, > if I'm not mistaken, since it is every other field. > > Thanks in advance, > MikeTo narrow down the problem, I would use an oscilloscope or TV waveform monitor to examine the source video stream... is the problem there too? Is it always the odd field that is brighter or does the change slowly drift through the video and sometimes the even field is brighter? In other words is the 30 Hz intererence "phase locked" to the video or is it just "close to" the video sync frequency? Mark Mark
Thanks for your response. Good point. I wasn't able to put it on a scope, but I did confirm that it isn't always on the odd field. I zoomed in and watched the live video feed and it seems the difference is there on both the odd and even fields. But it seems to be close to the timing. It may actually be much faster than 60 hertz (every other line) in each frame. I don't know much about it, but from my research on the internet, it seems that this would be classified as "hum bars". They are vertical and roll though the picture. (Although they roll so fast it is hard to notice. I can actually see fast waves and one big peak wave come through every 3 seconds or so if I zoom in on the live video.) Many sites said that hum bars come from electrical interference -- harmonics on the electrical line and/or ground loops. The camera and the computer are both on the same electrical circuit as the x-ray transformer and equipment. The interference seems to vary within the cycle based on what's going on with the machine. Based on this tomorrow we are going to try to put both the camera and the computer with the frame grabber on a UPS and then run an extension cord to an isolated "normal" circuit (i.e. no equipment). Hopefully this is a plausible theory. If it doesn't work, I'm out of ideas... Thanks again for your help. Mike
if the interference rolls through slowly, then it is probably due to power line related interference.... the power line (in the US) is 60 Hz and video vertical sync rate is 59.94 Hz. (someone check me on this number not sure right now) the point is is it a little off from 60 Hz so when you get interference from power line (hum bars) they roll through the picture slowly vertically. Note hum bars are HORIZONTAL bars that roll slowly through the picture vertically. You may be a ground loop or some other power line related intereference on the video cable that is interering in a sugtle way with the sync circuit. You should try to get a scope to look at the video.... Mark
Reply by ●January 26, 20062006-01-26
Well, the NTSC field frequency is 59.97 IIRC. Another possibility for this uneven brightness on odd/even fields can come from the light source. Whether it comes from a fluorescent or incandescent light source, it fill flicker at the same frequency as the power source (60Hz in the US). One quick test I would do to verify this is your actual source of the problem is to leave the power to your computer and camera as they are, and darken the door and illuminate an object with a good flashlight. If the uneveness is still there then it is the power supply (I hope is not one of those awful wall-warts). If it is gone you need to change your light source. If you use incandescent you can use a DC power source and your problem shoudl go away. Paolo
Thanks for your reply. The image is actually coming off of a camera inside an industrial x-ray machine, so I can't test it that way, but I have seen that effect you mention before under mercury vapor lights... Mike
Mark- Thanks for the reply. The test we tried today (isolating on a separate circuit) didn't work, but I'm not sure we got it truly isolated. Basically we can't see the wiring and we have sketchy documentation, it seemed when we did it that the camera and the control unit were on different power supplies (we previously thought the camer was fed from the control unit)... I'm not an electrical engineer or very experienced. I have used a scope once and do have access to one, but I'm not sure what I'd be looking for in this case. I've read about NTSC standards and seen the wave form though. Do you know of any sites that have directions? BTW, the video signal seems to be NTSC Composite Video 1 wire with a "setup component" that puts the black ref level at 0.054 volts. (Saw it in the manual for the port of the monitor that it is going into.) I'm not sure if it has a color component or not. (We have no English documentation and can't physically look at the camera.) I read in the NI manual that if the clamp timing is set wrong it showed an image that looked very similar to what we see, but I haven't been able to find clamp values that take care of it. Right now it's set to 106 through 116. Maybe tomorrow, I'll try the scope and see if I can figure anything out... Thanks again for your help. Mike
Reply by ●January 27, 20062006-01-27
Mike wrote:> Mark- > > Thanks for the reply. The test we tried today (isolating on a separate > circuit) didn't work, but I'm not sure we got it truly isolated. > Basically we can't see the wiring and we have sketchy documentation, it > seemed when we did it that the camera and the control unit were on > different power supplies (we previously thought the camer was fed from > the control unit)... > > I'm not an electrical engineer or very experienced. I have used a > scope once and do have access to one, but I'm not sure what I'd be > looking for in this case. I've read about NTSC standards and seen the > wave form though. Do you know of any sites that have directions? > > BTW, the video signal seems to be NTSC Composite Video 1 wire with a > "setup component" that puts the black ref level at 0.054 volts. (Saw > it in the manual for the port of the monitor that it is going into.) > I'm not sure if it has a color component or not. (We have no English > documentation and can't physically look at the camera.) I read in the > NI manual that if the clamp timing is set wrong it showed an image that > looked very similar to what we see, but I haven't been able to find > clamp values that take care of it. Right now it's set to 106 through > 116. > > Maybe tomorrow, I'll try the scope and see if I can figure anything > out... > > Thanks again for your help. > > Mikeif you have a ground loop this may help: http://www.epanorama.net/documents/groundloop/video_isolation.html or search on video ground loop also search on video waveform Mark
