in article 1138815145.765657.122150@o13g2000cwo.googlegroups.com, stevenj@alum.mit.edu at stevenj@alum.mit.edu wrote on 02/01/2006 12:32:> Robert Hay wrote: >> My problem actually is as follows: My program (in Java) gets two array of >> integers from another program, uses FFT or Inverse FFT depending on what >> the calling program requests, and returns two array of integers to the >> caller. The next time the caller may want to get its original signal by >> requesting from my program an Inverse FFT operation. > > This is an intrinsic problem -- integers cannot very accurately > represent the results of a DFTi don't presume the OP means integral values but fixed-point representation.> and using an integer FFT will do nothing to solve it.if there are enough bits in those integers (32+) and if there is some care taken to scaling - either "block floating-point" or, if that is computationally too messy, the "unitary" DFT scaling with 1/sqrt(N) so that there is a divide-by-two (or ASR) ever *other* FFT pass - if you do that, you can have some decent results. those LakeDSP guys (the same who either stole Bill Gardner's idea for zero-delay or low-delay fast convolution or came up with the idea independently and nearly simultaneously, also a believable POV) had an old convoluter built out of several Mot DSP56002, fixed-point DSPs, and i think it sounded pretty good. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Is there a sample Java code for fixedpoint FFT?
Started by ●January 25, 2006
Reply by ●February 1, 20062006-02-01
Reply by ●February 2, 20062006-02-02
r b-j wrote:> i don't presume the OP means integral values but fixed-point representation.A distinction without a difference; fixed-point vs. integers is just a choice of scale factors.> if there are enough bits in those integers (32+) and if there is some care > taken to scaling [...] you can have some decent results.The errors in a fixed-point FFT, which go as sqrt(N), are intrinsically worse than the errors in a floating-point FFT, which go as sqrt(log N) on average. Because of that, the OP is almost certainly better off using a floating-point FFT and converting to integers at the end with an appropriate scaling. Besides which floating-point FFTs are simpler to implement than fixed-point, and are probably faster as well on a modern general-purpose CPU. (We're not talking about DSP chips here, or embedded systems without an FPU.) Steven
