I am designing a reed solomon decoder encoder in verilog. while designing I was unable to calculate delta using Berlekmp massey algorithm. It will be great help if you can give me some hint. delta(k) = syndrome(k) - sumation( lambda(k-1) * syndrome(k -i) lambda is something like zx^3+ ax2+ bx+1 syndrome is y by solving this suppose we get the delta = k. http://www.ee.ucla.edu/~matache/rsc/node8.html if we multiply lambda with syndrome we should get some equation of the x^3 how that is reduced to just single k. for ex you can look at this link http://www.ee.ucla.edu/~matache/rsc/node9.html Regards Nitin
Reed solomon Berlekemp massey algorithm
Started by ●January 26, 2006
Reply by ●February 1, 20062006-02-01
