Hi, When looking at many of the video scalers and DSPs for consumer video, the datasheets usually list several cascaded polyphase FIR filters. They usually supply software libraries that generate the filter coefficients given a pair of numbers describing how much interpolation and decimation. In attempting to get a much better understanding of basic DSP skills, I started to build my own model of an image scaler. I am attempting to use a very small set of coefficients to mimic the constraints of a video scaler implemented in an FPGA. I figure with a typical FPGA I will have enough internal SRAM to buffer 4 to 6 lines of video, so I could potentially build a 6-tap filter. Most of the standard low-pass windowed filters are unsuited. The Remez equiripple has an astoundingly bad main lobe. I've decided that least-squares gives a reasonable magnitude and phase response. Two questions: 1) Where can I find more information on the least-squares method (I have Lyons 2004, Vaidyanathan 93, fliege 94) and I have a basic understanding of curve-fitting. I guess I don't understand what curve I'm trying to find. sinc? 2) Can somebody answer in simple terms how the DSP image scalers can work with such a small set of coefficients? e.g. assume a 512x512 source is to be converted to a 1024x1024 image. Interpolation x 2 with a 4-tap filter will allow me to use an 8x8 set of coefficients. Using the PM method, an optimal filter should have 372x372 coefficients. How do I get a good looking image with far less than 372x372 coefficients? Thanks, --Mike
2D image scaling using cascaded polyphase FIR filter
Started by ●January 26, 2006
Reply by ●January 26, 20062006-01-26
"michaelle" <michaelle@belkin.com> wrote in message news:2-KdnRjggK5EL0XenZ2dnUVZ_sCdnZ2d@giganews.com...> Hi, > > When looking at many of the video scalers and DSPs for consumer video, the > datasheets usually list several cascaded polyphase FIR filters. They > usually supply software libraries that generate the filter coefficients > given a pair of numbers describing how much interpolation and decimation. > > In attempting to get a much better understanding of basic DSP skills, I > started to build my own model of an image scaler. I am attempting to use > a very small set of coefficients to mimic the constraints of a video > scaler implemented in an FPGA. I figure with a typical FPGA I will have > enough internal SRAM to buffer 4 to 6 lines of video, so I could > potentially build a 6-tap filter. Most of the standard low-pass windowed > filters are unsuited. The Remez equiripple has an astoundingly bad main > lobe. I've decided that least-squares gives a reasonable magnitude and > phase response. > > Two questions: > 1) Where can I find more information on the least-squares method (I have > Lyons 2004, Vaidyanathan 93, fliege 94) and I have a basic understanding > of curve-fitting. I guess I don't understand what curve I'm trying to > find. sinc? > 2) Can somebody answer in simple terms how the DSP image scalers can work > with such a small set of coefficients? e.g. assume a 512x512 source is to > be converted to a 1024x1024 image. Interpolation x 2 with a 4-tap filter > will allow me to use an 8x8 set of coefficients. Using the PM method, an > optimal filter should have 372x372 coefficients. How do I get a good > looking image with far less than 372x372 coefficients?I think the issue is more one of understanding video processing, artifacts, etc. Very large filters aren't common for a lot of very practical video quality reasons *(and for processing loading reasons as well). I believe it's typical to use very short spatial filters in one dimension. So, there might be horizontal filters and there might be vertical filters that operate somewhat separately. Example for 2x interpolation: (it is not typical to filter before zero-stuffing) video line: x1 0 x2 0 x3 0 x4 0 x5 Interpolator [1/2 1 1/2] Result x1 (x2+x1)/2 x2 (x3+x2)/2 x3 (x4+x3)/2 x4 (x5+x4)/2 x5 You would probably interpolate in the horizontal before interpolating in the vertical just because the samples are more readily available and can be generated sooner - probably implies the need for less memory. What you mean by a "good looking image" is very important AND you probably don't mean "image" when one considers motion effects. For example, what happens if the video is showing a scene with a telephone pole seen from a fast-moving train? or a high rise building with lots of vertical window frames seen from a similar moving platform? etc. Fred
michaelle wrote:> > Hi, > > When looking at many of the video scalers ....blah blah blah> Using the PM method, an > optimal filter should have 372x372 coefficients.optimal? I would suggest you invest in a dictionary and look that word up.> How do I get a good > looking image with far less than 372x372 coefficients?You might try a spline based algorithm for upscaling. -jim ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
