Hi to everyone,: how can I extract Doppler information from a chirp impulse LFM like cos(2*pigreco*f0*t+k*pigreco*t^2) ?; At receiver I have cos(2*pigreco*f0*(t-2R/c)+k*pigreco*(t-2R/c)^2), multipling by cos(2pigrecof0t) and low pass filtering I obtain cos(-2*pigreco*f0*2R/c+k*pigreco*(t-2R/c)^2). I would like to get this term apart from others: cos(-2*pigreco*f0*2R/c) to work it on. Thank you very much to everyone who want to help me davide
problems with chirp LFM impulse in radar
Started by ●July 20, 2004
Reply by ●July 29, 20042004-07-29
Hi David May be I don't understand your question properly I think you are trying to get the doppler from a single chirp pulse ? from my limited knowledge i don't think you can get the doppler info from a single pulse. radar usally transmit a number of pulses, on the returned pulses we take the FFT on range wise. from which we can easily measure the doppler of the target. regards bijoy "Davide" <dgramugTIDIMEZZO@tin.it> wrote in message news:<Vi9Lc.23550$OR2.1182651@news3.tin.it>...> Hi to everyone,: > how can I extract Doppler information from a chirp impulse LFM like > cos(2*pigreco*f0*t+k*pigreco*t^2) ?; > At receiver I have cos(2*pigreco*f0*(t-2R/c)+k*pigreco*(t-2R/c)^2), > multipling by cos(2pigrecof0t) and low pass filtering I obtain > cos(-2*pigreco*f0*2R/c+k*pigreco*(t-2R/c)^2). > I would like to get this term apart from others: cos(-2*pigreco*f0*2R/c) to > work it on. > Thank you very much to everyone who want to help me > > > davide
Reply by ●August 3, 20042004-08-03
pbijoy@rediffmail.com (bijoy) wrote in message news:<261d3065.0407290444.72663df8@posting.google.com>...> Hi David > May be I don't understand your question properly > > I think you are trying to get the doppler from a single chirp pulse ? > > from my limited knowledge i don't think you can get the doppler info > from a single pulse. > > radar usally transmit a number of pulses, on the returned pulses we > take the FFT on range wise. > > from which we can easily measure the doppler of the target. > > > regards > bijoy > > "Davide" <dgramugTIDIMEZZO@tin.it> wrote in message news:<Vi9Lc.23550$OR2.1182651@news3.tin.it>... > > Hi to everyone,: > > how can I extract Doppler information from a chirp impulse LFM like > > cos(2*pigreco*f0*t+k*pigreco*t^2) ?; > > At receiver I have cos(2*pigreco*f0*(t-2R/c)+k*pigreco*(t-2R/c)^2), > > multipling by cos(2pigrecof0t) and low pass filtering I obtain > > cos(-2*pigreco*f0*2R/c+k*pigreco*(t-2R/c)^2). > > I would like to get this term apart from others: cos(-2*pigreco*f0*2R/c) to > > work it on. > > Thank you very much to everyone who want to help me > > > > > > davideThe problem isn't the single pulse, it's the pulse type. The chirp pulse is doppler insensitive. To extract doppler information you could use a bank of matched filters, each replica corresponding to a different doppler value. Unfortunately these will be pretty widely spaced apart because of the doppler insensitivity. You should look at an ambiguity diagram for you pulse. Normally replicas are placed at the 3dB points. If you used a CW pulse the doppler information is detected by the frequency shift, and the bank of matched filters conveniently turns into a FFT filter bank. Cheers, David
