how to generate a pulse train for sampling a signal?
sampling theorem
Started by ●January 28, 2006
Reply by ●January 28, 20062006-01-28
"ravirevolt" <ravirevolt@yahoo.co.in> writes:> how to generate a pulse train for sampling a signal?One way is to connect the trigger of an infinite impulse generator (I think HP makes one) to a square wave signal generator with the desired sampling frequency. You should ensure the cables you're using are well-shielded as the IIG generates lots of interference. -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:> "ravirevolt" <ravirevolt@yahoo.co.in> writes: > > > how to generate a pulse train for sampling a signal? > > One way is to connect the trigger of an infinite impulse generator (I > think HP makes one)Wasn't that Tectronix? I think the model is discontinued by now...> to a square wave signal generator with the desired > sampling frequency. You should ensure the cables you're using are > well-shielded as the IIG generates lots of interference.I think it might use a little bit more power than your local power vendor might appreciate, as well... Ravirevolt, we are kidding. The pulse train you see in the mathemathical descriptions of the sampling process are merely mathematical idealizations (some would say obfuscations) of a simple technical process. Try to google for "sample and hold ADC" to find out how sampling is really performed. Rune
Reply by ●January 30, 20062006-01-30
Rune Allnor wrote:> I think it might use a little bit more power than your local power > vendor might appreciate, as well...Hmm, Perhaps the Tectronix model wasn't really power efficient then, the HPs model generates fine those finite energy, but infinite amplitude impulses with two AAA batteries. ;)
