I am trying to implement a costas loop in matlab.The code which i have written is based on blockwise most of it using the available functions of the matlab...the signal frequency 600bits/sec and the carrier frequency is 3khz.In trackin the error the the lowpass filter used is butterworth filter...after removing the carrier frequency component....the left value should be just a dc componet which should be a constant value theoretically....but in realtime i has some settling time which is almost double the symboltime...so tracking the carrier with this loop is very tough with what i did....is there any other alternative way in which you have implemented this system....if you can post your code it will be very helpful and evena general pll code will be useful (but the implementation should be block wise rather than using the loop equations)
Problem With Implementation of costas loop In MATLAB
Started by ●January 30, 2006
Reply by ●February 6, 20062006-02-06
As i have mentioned above the carrier frequency is not 3khz.but it is 9khz.can some one please comment on the filter design in the above system...i have been using butterworth filter of order 8th due to which ther eis unstability in the dc response...can someone suggest an alternative filter which might improve the filter stability...
Neophyte wrote:> As i have mentioned above the carrier frequency is not 3khz.but it is > 9khz.can some one please comment on the filter design in the above > system...i have been using butterworth filter of order 8th due to which > ther eis unstability in the dc response...can someone suggest an > alternative filter which might improve the filter stability...I like to use baseband loops with full complex multiplies, so that the image term mathematically cancels and there are no "arm" filters at all. John
