Hello, I'm working on a project that involves a DSP/microprocessor communication I have the RCM3000 RabbitCore (Development Kit). The Auxiliary I/O Bus has 8 data and 6 address (shared with I/O), plus I/O Read-Write. I'm trying to configure the C6713 DSP external memory interface(EMIF) to think that the microprocessor is an asynchronous memory. In this way, I could tie the CE2 or CE3 pin to an interruptible microprocessor pin.This way, the DSP could interrupt the microprocessor whenever it wants to transmit data. I haven't used the Rabbit processor before, but it's perfect for what I'm working on because it has an ethernet capabiity. I'm planning to use the rabbit microprocessor, to continoulsy accept the data processed by the DSP and update a webpage through ethernet. Is is possible for me to configure the rabbit processor auxiliary I/O bus as an asynchronous memory. If possible how do I go about doing this? Any example source code will help a lot. Thanks, Bernard.
TMS320C6713/RCM3000 Rabbitcore communnication
Started by ●January 30, 2006
