Phil wrote:> Jerry Avins permanently inked into the cyberlog:...>>Either the wire is continuous or it isn't. A piece of #30 is enough. >>What does "as good as it should be" mean? > > > There were some pinches but I don't think I am correct about that.?? You can't dim a light by tying knots in the cord. (>>>I just checked my monitor and it is 68.76khz and vert 85.22 hz. But)>>>I believe I was near the tv when it showed humming. >> >>Clearly. That's the only source of 15,750. > > > I'm not clear on how high freq alias but do you mean the 68.76 is > aliased as 15.75No. I mean that a TV display is the only likely source of 15,750. (525 lines/frame) * (30 frames/second) = 15750 lines/second. ...>>Bingo! The microphone pellet isn't grounded? Then it's an antenna of >>sorts. Tie it to the cable shield or put in a shielded container. > > > Ok, I suspect something was amis there, I had played with various things > along with touching the case, and I did notice shorting the ground to > the case relieved it, also there is a small tab to the case near the > ground solder joint and It appears it should have been part of the > ground joint or not, I wasn't sure and now you've helped me there. > > Can I solder it or will I destroy the condenser. Its close enough to > the case, about 1 mm, that I should be able to do it.That tab was probably a spring contact, which means they didn't dare solder. (Heat can depolarize an electret.) Twist bare wire around the pellet leaving a tail, and solder to that. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
microphone hum
Started by ●January 31, 2006
Reply by ●February 1, 20062006-02-01
Jerry Avins permanently inked into the cyberlog:> Phil wrote: >> Jerry Avins permanently inked into the cyberlog: > > ... > >>> Either the wire is continuous or it isn't. A piece of #30 is enough. >>> What does "as good as it should be" mean? >> >> >> There were some pinches but I don't think I am correct about that. > > ?? You can't dim a light by tying knots in the cord.ho, I meant I was wondering if the pinched wire had broken the shielding connection and it may have been a compromised connection but I don't think so since moving the wire doesn't cause the hum.> > (>>>I just checked my monitor and it is 68.76khz and vert 85.22 hz. > But) > > >>>> I believe I was near the tv when it showed humming. >>> >>> Clearly. That's the only source of 15,750. >> >> >> I'm not clear on how high freq alias but do you mean the 68.76 is >> aliased as 15.75 > > No. I mean that a TV display is the only likely source of 15,750. > (525 lines/frame) * (30 frames/second) = 15750 lines/second. > > ... > >>> Bingo! The microphone pellet isn't grounded? Then it's an antenna of >>> sorts. Tie it to the cable shield or put in a shielded container. >> >> >> Ok, I suspect something was amis there, I had played with various >> things along with touching the case, and I did notice shorting the >> ground to the case relieved it, also there is a small tab to the >> case near the ground solder joint and It appears it should have been >> part of the ground joint or not, I wasn't sure and now you've helped >> me there. >> >> Can I solder it or will I destroy the condenser. Its close enough to >> the case, about 1 mm, that I should be able to do it. > > That tab was probably a spring contact, which means they didn't dare > solder. (Heat can depolarize an electret.) Twist bare wire around the > pellet leaving a tail, and solder to that. > > ... > > Jerryok, I'll give that a go, thanks a lot. -- Phil
Reply by ●February 3, 20062006-02-03
I messed with it too much and the signal wire broke, So instead of pitching it I resoldered it and the ground and now it works, no more hum. I guess the heat didn't affect it. Jerry Avins permanently inked into the cyberlog:> Phil wrote: > > That tab was probably a spring contact, which means they didn't dare > solder. (Heat can depolarize an electret.) Twist bare wire around the > pellet leaving a tail, and solder to that. > > ... > > Jerry-- Phil
Phil wrote:> I messed with it too much and the signal wire broke, So instead of > pitching it I resoldered it and the ground and now it works, no more > hum. I guess the heat didn't affect it.Good fix! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
