Does the basestation vary the transmit power of PDCH downlink bursts on the same phyisical channel (time slot) depending on which MS it is intended for, or is the DL transmit power constant for all bursts on single PDCH channel? thanks. @8631000@
GPRS DL burst power?
Started by ●January 31, 2006
Reply by ●January 31, 20062006-01-31
nearly_blind@yahoo.com wrote:> Does the basestation vary the transmit power > of PDCH downlink bursts on the same phyisical channel (time slot) > depending on which MS it is intended for, or is the DL transmit power > constant for all bursts on single PDCH channel? > thanks. > @8631000@ >To my knowledge, the GSM BS does not adapt the transmit power, i.e. the power is constant for all timeslots in PDCH. The power is adapted only on the MS side for the purpose of the battery saving. However the last time I was involved with the GSM was over 10 years ago. The specs may have changed since then. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
