Can anyone help me in the way of datatapping/sniffing a dial-up modem connection by only access to the complex signals carries in the 2-wire link(listening to the voice)? For this purpose it should be to separate the incoming and outgoing signals in full-duplex mode, then demodulating them according to the standard of connection. The most public standard is V.34 uses QAM modulation. Now: -Is it possible to separate the signals in each direction in full-duplex mode by hardware or bye any software way? -Is there any way after separating the signals to demodulating them(especially in QAM) completely? Thanks all
Modem datatapping/sniffing
Started by ●February 6, 2006
Reply by ●February 6, 20062006-02-06
hamid_brj wrote:> Can anyone help me in the way of datatapping/sniffing a dial-up modem > connection by only access to the complex signals carries in the 2-wire > link(listening to the voice)?For the modern protocols this is not feasible. You have to cut in between the modems. Even if you can separate the sides of the link, the sniffed data is likely to be unreliable. The only practical method is man-in-the-middle. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky wrote:> > > hamid_brj wrote: > >> Can anyone help me in the way of datatapping/sniffing a dial-up modem >> connection by only access to the complex signals carries in the 2-wire >> link(listening to the voice)? > > > For the modern protocols this is not feasible. You have to cut in > between the modems. Even if you can separate the sides of the link, the > sniffed data is likely to be unreliable. The only practical method is > man-in-the-middle.To elaborate, if the modem uses echo cancellation you won't be able to decode things by sniffing. If it doesn't use echo cancellation you will be able to decode by sniffing. This pretty much limits you to V.22bis or below for full duplex modems. Most FAX modems work in ping-pong mode, so you can decode those. Regards, Steve
hamid_brj wrote:> Can anyone help me in the way of datatapping/sniffing a dial-up modem > connection by only access to the complex signals carries in the 2-wire > link(listening to the voice)?There are no complex signals on two-wire links.> For this purpose it should be to separate the incoming and outgoing > signals in full-duplex mode,Yes. You need a "hybrid" to do that, and to match the line impedances. That can't be done with a tap, but if you can cut the line and insert the proper equipment, the reconnected line should behave normally. For further details, consult NSA.> then demodulating them according to the > standard of connection. The most public standard is V.34 uses QAM > modulation. Now: > -Is it possible to separate the signals in each direction in full-duplex > mode by hardware or bye any software way? > -Is there any way after separating the signals to demodulating > them(especially in QAM) completely?Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
hamid_brj wrote:> Can anyone help me in the way of datatapping/sniffing a dial-up modem > connection by only access to the complex signals carries in the 2-wire > link(listening to the voice)?Ever since it came out the GWB had the NSA perform wire taps without a warrant, I have noticed the number of questions related to telephony (and related) on comp.dsp has sky-rocketed. DTMF, mu-law, call-progress, upsampling 8KHz audio, and now this. Is it all a coincidence? -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 When you're great, people often mistake candor for bragging. - Calvin
Reply by ●February 8, 20062006-02-08
> below for full duplex modems. Most FAX modems work in ping-pong mode, so > you can decode those.Is any free soft to decode fax signals? Regards, Zbi
try Spandsp - http://www.soft-switch.org/ please let me know if it really works -Clark "news.aster.pl" <zka@tenbit.pl> wrote in message news:43ea6e90$0$1469$f69f905@mamut2.aster.pl...> > below for full duplex modems. Most FAX modems work in ping-pong mode, so > > you can decode those. > > Is any free soft to decode fax signals? > > Regards, > Zbi > >
Reply by ●February 9, 20062006-02-09
Can you spell J-A-I-L T-I-M-E ? Dirk hamid_brj wrote:> Can anyone help me in the way of datatapping/sniffing a dial-up modem > connection by only access to the complex signals carries in the 2-wire > link(listening to the voice)? > For this purpose it should be to separate the incoming and outgoing > signals in full-duplex mode, then demodulating them according to the > standard of connection. The most public standard is V.34 uses QAM > modulation. Now: > -Is it possible to separate the signals in each direction in full-duplex > mode by hardware or bye any software way? > -Is there any way after separating the signals to demodulating > them(especially in QAM) completely? > > Thanks all
Dear Vladimir, Steve, Jerry, and others Do you know any equipment to insert between the line to separate signal in each direction and have no effect on the connection? Is it only a hybrid and which hybrid or it should be in the form of man-in-the-middle? Does tow-way telephone voice connection(includes dialup modem connections) separate in PSTN centers using any hybrid, and if so, can we use the equipment in this way? Is there any available equipment in market or I should design it? Isn�t there any software solution for this project at all? Thanks in advance
Really hamid, If this project is done for the wrong people it would be illegal in the US. So who are you and who are you doing it for? My feeling is that since you have to ask these questions here it can't be for anyone good. Are you just curious or are you looking for co-conspirators? Dirk hamid_brj wrote:> Dear Vladimir, Steve, Jerry, and others > > Do you know any equipment to insert between the line to separate signal in > each direction and have no effect on the connection? Is it only a hybrid > and which hybrid or it should be in the form of man-in-the-middle? > Does tow-way telephone voice connection(includes dialup modem connections) > separate in PSTN centers using any hybrid, and if so, can we use the > equipment in this way? > Is there any available equipment in market or I should design it? Isn't > there any software solution for this project at all? > > Thanks in advance
