Modem datatapping/sniffing
Started by hamid_brj ●February 6, 2006
I imagine that you might be able to expand on the principle of an RF
directional coupler to perform direction separation.  It relies on the
Tx & Rx line currents going in opposite directions for the same
instantaneous applied voltage polarity.
You would have to untwist a (uncertain-sized) portion of the twisted
pair to access the magnetic field.  Capacitive coupling to a hi-Z load
would suffice to tap the signal voltages.  By use of a little scaling
plus summing, differencing & phasing (allowance for reactive line
loads) you could probably tease out the 2 two directions with at least
20dB margin.
If you were to write some DSP code (probably based on LMS echo canceller
concepts) to continually maximise the difference between the 2
recovered signals, you might make 40dB.  Which might be enough.
Such code could automatically take care of the phasing & balancing stuff
for you.  Otherwise the mechanical tolerances for maintaining an
established balance would be too subject to being nudged.
Biggest problem would be getting a decent signal from the magnetic
field.  Normal off-the-shelf hall-effect devices are fairly deaf.
Anyone know anything about squids?
Just guessing.
Jim Adamthwaite
hamid_brj wrote:
> Dear Vladimir, Steve, Jerry, and others > > Do you know any equipment to insert between the line to separate signal in > each direction and have no effect on the connection? Is it only a hybrid > and which hybrid or it should be in the form of man-in-the-middle? > Does tow-way telephone voice connection(includes dialup modem connections) > separate in PSTN centers using any hybrid, and if so, can we use the > equipment in this way? > Is there any available equipment in market or I should design it? Isn�t > there any software solution for this project at all? > > Thanks in advance
Hamid, I don't know what you want this for, or whose lines you propose to insert equipment is series with. This is in any event not the best forum for learning basic telephony. With the right circuit, it is possible to have identical signal sets in separate locations which are connected together with a single wire and earth return. A switch in each set controls an indicator in the other. You will have some of the tools to do what you want when you understand how to design such a system. Once you have stirred cream into coffee, no software can separate them. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jim Adamthwaite wrote:
> I imagine that you might be able to expand on the principle of an RF > directional coupler to perform direction separation. It relies on the > Tx & Rx line currents going in opposite directions for the same > instantaneous applied voltage polarity. > > You would have to untwist a (uncertain-sized) portion of the twisted > pair to access the magnetic field. Capacitive coupling to a hi-Z load > would suffice to tap the signal voltages. By use of a little scaling > plus summing, differencing & phasing (allowance for reactive line > loads) you could probably tease out the 2 two directions with at least > 20dB margin. > > If you were to write some DSP code (probably based on LMS echo canceller > concepts) to continually maximise the difference between the 2 > recovered signals, you might make 40dB. Which might be enough. > > Such code could automatically take care of the phasing & balancing stuff > for you. Otherwise the mechanical tolerances for maintaining an > established balance would be too subject to being nudged. > > Biggest problem would be getting a decent signal from the magnetic > field. Normal off-the-shelf hall-effect devices are fairly deaf. > Anyone know anything about squids? > > Just guessing. > Jim Adamthwaite
Jim, I know how to tap phones. I also know how to make bombs and silencers. I don't do those things because doing them is illegal. I don't tell others how to do them because both my moral sense and prudence dictate against aiding and abetting a crime. Discussing general principles seems OK to me; that's as far as I'll go. Jerry P.S. Relax: an RF-type directional coupler isn't likely to work. -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:
> > I know how to tap phones. I also know how to make bombs and silencers. I > don't do those things because doing them is illegal. I don't tell others > how to do them because both my moral sense and prudence dictate against > aiding and abetting a crime. Discussing general principles seems OK to > me; that's as far as I'll go. > > Jerry > > P.S. Relax: an RF-type directional coupler isn't likely to work.
What does US law have to say about supplying the tools for wiretapping? There are several software packages for decoding FAX transmissions from a wave file. I can't see much use for these, apart from wire tapping. They aren't sold only to law enforcement people. Steve
Jim Thomas wrote: since it came out the GWB had the NSA perform wire
taps without a
> warrant, I have noticed the number of questions related to telephony > (and related) on comp.dsp has sky-rocketed. > > DTMF, mu-law, call-progress, upsampling 8KHz audio, and now this. > > Is it all a coincidence? >
Maybe. According to this WSJ report, authorized wiretaps have risen 44% in the past couple of years: http://online.wsj.com/public/article/SB113945527128569215-ap0UyM9HXxWBrOiAX0msQpD4xsw_20070209.html?mod=blogs -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Quidquid latine dictum sit, altum sonatur. Whatever is said in Latin sounds profound.
Check yahoo news in the last week.
Steve Underwood wrote:
> Jerry Avins wrote: > >> >> I know how to tap phones. I also know how to make bombs and silencers. >> I don't do those things because doing them is illegal. I don't tell >> others how to do them because both my moral sense and prudence dictate >> against aiding and abetting a crime. Discussing general principles >> seems OK to me; that's as far as I'll go. >> >> Jerry >> >> P.S. Relax: an RF-type directional coupler isn't likely to work. > > > What does US law have to say about supplying the tools for wiretapping? > There are several software packages for decoding FAX transmissions from > a wave file. I can't see much use for these, apart from wire tapping. > They aren't sold only to law enforcement people.
There are weather maps broadcast as facsimile from stations along the coast. Beating the FSK to baseband with a BFO and recording the result in a wave file is the common way to receive those. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
With due attention to anxiety of some persons in this site about my
questions, I should to state some points:
1- I�m outside of US and therefore not under of it�s laws.
2- In spite of all that, there is anti-eavesdropping law in our region.
3- We talk here about a scientific subject inattentive to final use of the
made tool. I have not said anywhere that for which application I want this
tool. Are you sure I want it for eavesdropping or only for personal use
and research?
4- Although weapon and bomb are dangerous tools, but is it impossible to
talk about them and how making them(scientific point of view )? And if so,
how so many weapons are made every day? I think what is important is the
proper use of these, not talking about them!
Thanks all
Hamid
Hamid,
hamid_brj wrote:
> --------- > With due attention to anxiety of some persons in this site about my > questions, I should to state some points: > 1- I'm outside of US and therefore not under of it's laws. > 2- In spite of all that, there is anti-eavesdropping law in our region.
Abuse of technology does not need to be against the law to be abuse. Could be against the US or someone else that we don't want to support.
> 3- We talk here about a scientific subject inattentive to final use of the > made tool. I have not said anywhere that for which application I want this > tool. Are you sure I want it for eavesdropping or only for personal use > and research?
I think not knowing specifically how you are go to use it is enough to shy away from providing assistance to you. I don't think we simply take your word here. Again, if it was properly sanctioned, this is not where you would get your info.
> 4- Although weapon and bomb are dangerous tools, but is it impossible to > talk about them and how making them(scientific point of view )? And if so, > how so many weapons are made every day? I think what is important is the > proper use of these, not talking about them! >
There has been no discussion of the proper use here, only about how to make them. Discussion of the first topic would not make the second topic okay.
> Thanks all > Hamid
You are quite welcome, Dirk
dbell
>I think not knowing specifically how you are go to use it is enough to >shy away from providing assistance to you. I don't think we simply >take your word here. Again, if it was properly sanctioned, this is not >where you would get your info. > >
So, where can I get more info about this topics? I want in first step to know that is there any solution for this project that I start working on it or no? Thanks Hamid
