kirgizz wrote:> Hello board, > > I'm dealing with synchronisation issue and looking for a cheap solution > for my design. > > > Firstly, my external reference frequency is variable and can change, for > example, in sweep mode (5Hz per sec). Secondly, the exact information > about > the ext. reference frequency is used for internal calculations in DSP (to > generate frequency-locked quadrature sine waves). > That's why I'd like to implenent PLL in software (like 4046 series). > > I have an EZ-Kit lite DSP board from ADI with ADSP21262 onboard as basis > (fclk=200Mhz). So I assume, it suits my design. > > > more detailed: > -reference signal in: TTL, 20Hz-20kHz > -output signal: freq-locked sine waves > -jitter (sync error): 0.01Hz (@20kHz) > > I read some ebooks about PLL so I understand (theoretically) its > functionality. Furthermore I have implemented the loop filter and the NCO > (in place of VCO). > > My problem is the phase detector PFD. How can I program a simple and > precise lead-lag detector? In order to avoid additional hardware I'd > rather use an ADC for sampling. > > > Can you help me with an advice, please (detailed)? > Maybe there are alternatives. > > > Thank you in advance > kirgizz >Implementing a PLL in software uses the same basic theory as implementing a PLL in hardware -- you compare your synthesized signal to a reference, generate a phase difference, then servo the frequency of your synthesized signal to your reference. Software PLLs have some significant advantages over hardware PLLs, mostly in the reliability of the VCO and the ability to easily concoct complicated loops without having it show up as an embarrassing second PC board. They have some significant difficulties, as well, mostly having to do with the fact that you're operating in sampled time. Most of the problems you will encounter will be because of the sampled-time nature of a software-based loop. For a logic-level input signal my favorite phase detector is a timer capture input. If this is available it should be able to sample the state of a free-running timer at the instant that the reference signal changes from low to high (or visa-versa). Once this sample is taken you have a nice, unambiguous measure of the time that the transition happened to a precision proportional to the clock speed of your timer. You can use this time to compare to the state of your NCO phase accumulator (with appropriate interpolation between NCO sampling periods) and do whatever you want with your NCO command as a result. If you must feed the logic-level signal into an ADC then you will run into severe problems with aliasing. The sharp edges of the incoming signal will cause the phase measurement to be ambiguous by the ADC sampling interval, which will make it impossible to lock precisely. If you must use the ADC input then you should use anti-alias filtering to soften up the edge -- which means that you should be sampling well in excess of your 20kHz maximum signal frequency, probably 50kHz at a minimum. To determine the phase difference of your signal you just multiply the ADC reading by the output of your NCO and average (or low-pass filter) -- if you want faster lock you can get make a phase/frequency detector by using both the inphase and quadrature output of your NCO, and look at the phase rotation of the two averages (this is why software PLL's can be nice...). This is more a DSP question than electronics design, so I'm taking the liberty of cross-posting my response to the DSP newsgroup. Maybe someone there will have some good insights. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Re: Software PLL (SPLL)
Started by ●February 6, 2006
