Hi all I have a board with 6 daisy chained AD7687 pulsar ADCs. I have these ADC connected via a FPGA to an ADSP2186 running at 40MHz. Signals I'm measuring are in the 45 to 65Hz range. I employ a synchronous sampling mechanism where the sampling rate is always a 2^N multiple of the incoming base frequency. In this specific case e.g. for 50Hz the sample rate is 50x128x8=51200Hz. In the DSP I use autobuffering to buffer 48 samples = 8 samples/channel between SPORT interrupts. After every autobuffer interrupt I average the 8 samples/channel to give an effective sample rate of 50x128=6400Hz. The problem I'm having is when I change the input signals frequency to say 60Hz, thus changing the sample rate to 61440Hz, the magnitude of the sampled signal changes by about -60dB. I verify this by calculating the RMS at both 50 and 60Hz and I get a difference of about 20 counts in 18000. By this I mean that e.g. if the RMS value (in raw ADC counts) is 18000 at 60Hz, it is 18020 at 50Hz - the weirdest thing is that going down to 45Hz, the RMS value is again approximately the same as at 60Hz. I've used two precision AC calibrators (one being a Fluke 6100 power calibrator) to inject signals into the board - both exibit the same phenomena. I've tried with an oversampling of both 4 and 8 (8 in the example above), with the same result. Keeping the sample rate fixed at say 61440Hz and varying the input signal frequency from 45 to 65Hz - the sampled signal magnitude stays the same. I only have a single order anti-aliasing filter with the -3dB point at 15kHz (100R and 100nF). Could this still be caused by aliasing? I've already bypassed all the input amplifiers and injected directly into the ADCs with a very low distortion AC calibrator. Any ideas? Regards Pierre
AD7687 and ADSP218
Started by ●February 6, 2006
