Dougal McDougal of that Elk wrote:> You need to watch the stability - ie phase margin. Make sure you sample at > about ten times the unity gain cross-over freq. Your unity gain freq could > be around 12Hz - this should filter out the 2f at 120Hz. You may also need a > phase-lead compensator depending on the number of integrators you want (ie > for just the VCO you have one integrator - but you can add a phase-lag to > increase the slope). You need a Bode Plot in your head or on paper.If you > use a low-pass filter this will introduce phase lag and the amount depends > on the order of teh filter. The more you filter, the less 2f carrier > feedthrough but the more instability.Since this is being done in software, can't one get rid of all the phase lead/lag problems by using identical linear phase FIR filters on both the reference input and the VCO? Thanks. -- rhn A.T nicholson d.0.t C-o-M
Re: Software PLL (SPLL)
Started by ●February 8, 2006
