Ron N. wrote:> Tim Wescott wrote: > >>Implementing a PLL in software uses the same basic theory as >>implementing a PLL in hardware -- you compare your synthesized signal to >>a reference, generate a phase difference, then servo the frequency of >>your synthesized signal to your reference. > > > Why? Isn't a software PLL just a forward interpolator. Why not just > estimate (statistical, FFT, phase vocoder or otherwise) the frequency, > phase, derivatives of phase, etc.; generate a forward interpolation of > the input reference using that information, and call that the output of > the PLL NCO? Recalculate periodically (every sample if the compute > power is available). > > > rhn A.T nicholson d.0.t C-o-M >yuck! you would have to work quite very to match, let alone beat, the performance you can get from a software PLL, requiring negligible computational overhead. swatting flies with Howitzers often causes more problems than it solves. Cheers Terry
Re: Software PLL (SPLL)
Started by ●February 9, 2006
