Hello, I am going to implement a filter on a DSP. Before I do that I want to check that the filter works fine in matlab. So I have made a filter function in MATLAB: function [y,new_DelayLine1,new_DelayLine2]=filtx(x,num_b,den_a,old_DelayLine1,old_DelayLine2) where x is a row vector of samples. num_b and den_a are the numerator and denominator filter coefficients. If I generate a vector x with random data and use MATLABs filter and my own function I get the same output. As soon as I change the filter coefficients the output from MATLABs function and my own is no longer the same. How do I solve this? Here is the function: function [y,new_DelayLine1,new_DelayLine2]=filtx(x,num_b,den_a,old_DelayLine1,old_DelayLine2) K=size(x,2); M=size(num_b,2); N=size(den_a,2); for k=1:K % Filter (FIR) old_DelayLine1(1,1)=x(1,k); sum1=x(1,k)*num_b(1,1); for m=2:M sum1=sum1+old_DelayLine1(1,m)*num_b(1,m); end % Update FIR delay line for m=M-1:-1:1 old_DelayLine1(1,m+1)=old_DelayLine1(1,m); end % Filter (IIR) sum2=0; for n=2:N sum2=sum2+old_DelayLine2(1,n)*den_a(1,n); end % Filter output y(1,k)=(sum1-sum2)/den_a(1,1); % Update IIR delay line old_DelayLine2(1,1)=y(1,k); for n=N-1:-1:1 old_DelayLine2(1,n+1)=old_DelayLine2(1,n); end end new_DelayLine1=old_DelayLine1; new_DelayLine2=old_DelayLine2; And here is the test program: clc close all clear % generate new samples x=randn(1,10); % define filter [num_b,den_a]=butter(4,0.2); % reset delay lines used in my function new_DelayLine1=zeros(1,size(num_b,2)); new_DelayLine2=zeros(1,size(den_a,2)); % reset filter state for MATLABs filter function s=zeros(1,4); % Use my function to calculate filter output [y,new_DelayLine1,new_DelayLine2]=filtx(x,num_b,den_a,new_DelayLine1,new_DelayLine2); % Use MATLABs filter function [z,s]=filter(num_b,den_a,x,s); y % OK z % OK % Check that functions perform the same way when x is varying % new samples x=randn(1,10); % Use my function to calculate filter output [y,new_DelayLine1,new_DelayLine2]=filtx(x,num_b,den_a,new_DelayLine1,new_DelayLine2); % Use MATLABs filter function [z,s]=filter(num_b,den_a,x,s); y % OK z % OK % Check that functions perform the same way when x is varying AND filter is varying % new samples x=randn(1,10); % update filter coefficients [num_b,den_a]=butter(4,0.6); % filter [y,new_DelayLine1,new_DelayLine2]=filtx(x,num_b,den_a,new_DelayLine1,new_DelayLine2); [z,s]=filter(num_b,den_a,x,s); % Output y and z is not the same anymore y z
Filter question: Problem with time-varying filter
Started by ●February 9, 2006
Reply by ●February 9, 20062006-02-09
Hmmm...I guess it takes time for the filter to converge towards zero. Therfore, I must add the extra non-zero samples from the filter-output to the filter-output for the next block of samples. Right?
"James" <james@nadaspam.thanx> wrote in message news:43eb619e$0$78279$157c6196@dreader1.cybercity.dk...> Hmmm...I guess it takes time for the filter to converge towards zero. > Therfore, I must add > the extra non-zero samples from the filter-output to the filter-output for > the next block of > samples. Right? >James, That's a heck of a lot of code to deal with. What are you doing *in English*? You might get more responses. Fred
> > That's a heck of a lot of code to deal with. > > What are you doing *in English*? You might get more responses. > > FredSorry about that. Let me try in english then... I am trying to implement a filter in MATLAB: H[z]=(b[0]+b[1]*z^-1+.....+b[N]*z^-N) / (a[0]+a[1]*z^-1+.....+a[M]*z^-M) that will act like MATLABs own filter-function: [y,s]=filter(num,den,x,s) I have transfered the above function from the Z-domain to the time-domain and implemented the resulting expression as a function in MATLAB. It works fine as long as the filter-coefficients don't change from one block of samples to the next block of samples. However, as soon as I change the filter-coefficients from one block to another I get one result using MATLABs filter function and another result using my own function. I suspect it is because I have forgotten to implement some code that adds the transient signal from the filtering of block j to the filter output when processing block j+1....but I am not sure...
"James" <james@nadaspam.thanx> wrote in message news:43eb7b4e$0$78287$157c6196@dreader1.cybercity.dk...> >> >> That's a heck of a lot of code to deal with. >> >> What are you doing *in English*? You might get more responses. >> >> Fred > > > Sorry about that. > > Let me try in english then... > > I am trying to implement a filter in MATLAB: > > H[z]=(b[0]+b[1]*z^-1+.....+b[N]*z^-N) / (a[0]+a[1]*z^-1+.....+a[M]*z^-M) > > that will act like MATLABs own filter-function: > > [y,s]=filter(num,den,x,s) > > I have transfered the above function from the Z-domain to the time-domain > and > implemented the resulting expression as a function in MATLAB. > > It works fine as long as the filter-coefficients don't change from one > block of > samples to the next block of samples. > > However, as soon as I change the filter-coefficients from one block to > another > I get one result using MATLABs filter function and another result using my > own function. > > I suspect it is because I have forgotten to implement some code that adds > the transient signal from the filtering of block j to the filter output > when > processing block j+1....but I am not sure... >James, I think you have the right idea. Note that the matlab function returns the initial transient (and the ending transient if you ask for it). You don't need the initial transient part at all if you're working with a "streaming" set of values for x. It looks like this: X1 X2 X3 X4 X5 X6 X7 X8 X9 0 0 0 0 1 0 0 0 1 1 0 0 1 1 1 0 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 0 0 1 1 0 0 0 1 0 0 0 0 Using a purely non-recursive structure so a=1 and let's have b=[1 1 1] Y1 Y2 Y3 Y4 Y5 Y6 Y7 Y8 Y9 0 0 0 0 1 0 0 0 1 2 0 0 1 2 3 0 1 2 3 3 1 2 3 3 3 1 2 3 3 2 1 2 3 2 1 1 2 2 1 0 1 1 1 0 0 YF YF YF YF YF YF YF YF YF 1 1 2 1 2 1 2 1 2 1 1 0 0 0 0 0 0 0 Here, each block for x represents a single sample shift in x so each block in y represents a single sample shift in y. I've also limited the sequence in x to a total length of 9. You could also look at x and y like this: b=[1 1 1] x=[0 0 0 0 1 1 1 1 1 0 0 0 0] y=[0 0 0 0 1 2 3 3 3 2 1 0 0] I think this means the following if you're using shorter blocks of x: Throw out the startup transient in all the Y vectors. Now we have: Y1 Y2 Y3 Y4 Y5 Y6 Y7 Y8 0 0 1 0 1 2 1 2 3 2 3 3 3 3 3 3 3 2 3 2 1 1 0 0 y=[1 2 3 3 3 2 1 0 0] This type of filter implementation is probably fine for dealing with long arrays of numbers. It's obviously complicated when dealing with a sequence of short blocks - for whatever reason you choose to do that. You also might ask, what if the blocks aren't overlapping but, rather, contiguous: X1 X2 X3 0 0 0 0 1 1 1 1 1 0 0 0 0 0 0 for x=[0 0 0 0 1 1 1 1 1 0 0 0 0 0 0] Take a look at the Ys and YFs: Y1 00001 11 * > 001 Y2 00012 21 Y3 00123 21 Y4 01233 21 * > 233 Y5 12333 21 Y6 12332 10 Y7 12321 00 * > 321 Y8 12210 00 Y9 11100 00 Y10 11000 00 * > 000 Y11 10000 00 Which parts of which ones should/can be thrown out: Throw out all the startup transients and compute an output for every N-L+1 (5-3+1=3) input block meaning that the overlap in input is the same as the length of the startup transient L-1=2 here. Now, that makes sense because there has to be enough extra input data to just make up the startup transient that will be thrown out. Fred
Thanks Fred. I am not sure if it answers my question though. However, I would be very happy if you could tell me how matlab calculates the final conditions? Using MATLAB notation: b=1 a=[0.5 0.2 0.1] s=[0 0] x=[1 2 3 4] [y,s]=filter(b,a,x,s) Result: y=2 3.2 4.32 5.632 s=-3.1168 -1.1264 The difference equation for the above filter is: y(n)=[x(n)-0.2y(n-1)-0.1y(n-2)]/0.5 Verification shows: y(1)=2 y(2)=3.2 y(3)=4.32 y(4)=5.632 Final Conditions: y(5)=-3.1168 y(6)=[x(6)-0.2y(5)-0.1y(4)]/0.5=(0-0.2*(-3.1168)-0.1*5.632)/0.5=0.1203 As you can see 0.1203 is not equal to the number -1.1264 which MATLAB returns in the variable s and I really don't understand why...??? Another question is also why stop at n=6. An IIR-filter has an infinite response so why choose n to stop at max(length(a),length(b))-1 as MATLAB does? Please help. Thank you.
Reply by ●February 10, 20062006-02-10
"James" <james@nadaspam.thanx> wrote in message news:43ebf95c$0$67258$157c6196@dreader2.cybercity.dk...> Thanks Fred. I am not sure if it answers my question though. > However, I would be very happy if you could tell > me how matlab calculates the final conditions?Well you're now asking about the hows and whys of matlab. I think if you Google on the functions you might learn about it. I don't see that I can add much for questions like this. But, a couple of comments: - read the definition of "zf" in "filter". Maybe it seems weird but at least it seems to be well defined. - for zf would you expect an array of infinite length? or, perhaps an array of length sufficient to run out of numeric significance? or, perhaps that the word length be increased to continue the sequence for more samples? Except the first one, the other two might make sense for somebody. I really don't know how people normally *use* this function. Maybe someone with experience with matlab and specifically "filter" for IIR might comment. ***! I didn't think of it before because I didn't pay that much attention but it seems pretty cool now that I do think about it: The zf provide you the initial conditions for the next block! Something like this: [Y1,ZF1]=filter(a,b,X1,ZF0) [Y2,ZF2]=filter(a,b,X2,ZF1) etc. where it appears the Xi can be contiguous, nonoverlapping blocks (made possible by retaining the initial conditions of the filter). It appears this helps a whole lot regarding the transients! It's sure a lot simpler. So, I learned something. Hope you did too. Fred
> ***! > I didn't think of it before because I didn't pay that much attention but > it seems pretty cool now that I do think about it: > The zf provide you the initial conditions for the next block! > > Something like this: > [Y1,ZF1]=filter(a,b,X1,ZF0) > [Y2,ZF2]=filter(a,b,X2,ZF1) > etc. > where it appears the Xi can be contiguous, nonoverlapping blocks (made > possible by retaining the initial conditions of the filter). > > It appears this helps a whole lot regarding the transients! It's sure a > lot simpler. So, I learned something. Hope you did too. > > FredThat's exactly why I want to find out how the algorithm works because I have to implement it in C.
"James" <james@nadaspam.thanx> wrote in message news:43ed2bf5$0$78281$157c6196@dreader1.cybercity.dk...>> ***! >> I didn't think of it before because I didn't pay that much attention but >> it seems pretty cool now that I do think about it: >> The zf provide you the initial conditions for the next block! >> >> Something like this: >> [Y1,ZF1]=filter(a,b,X1,ZF0) >> [Y2,ZF2]=filter(a,b,X2,ZF1) >> etc. >> where it appears the Xi can be contiguous, nonoverlapping blocks (made >> possible by retaining the initial conditions of the filter). >> >> It appears this helps a whole lot regarding the transients! It's sure a >> lot simpler. So, I learned something. Hope you did too. >> >> Fred > > That's exactly why I want to find out how the algorithm works because > I have to implement it in C. > > >Oh, is that all... in that case: Note what it does. I think that's all the specification you need: It computes the output of a filter under two different situations: - Initial conditions given. - Initial conditions not given - assumed to be zero. If the initial conditions aren't given then it computes all of the output samples including the startup transient and the decay transient. The startup transient is included in the standard "output" and the filter state in a separate array. If the initial conditions *are* given, then it computes all of the output samples with no startup transient (assuming that the next input has some relation to the previous input). The provision of the initial conditions avoid a startup transient so inputs can be in contiguous blocks. The equations don't change, only the initial conditions. /---\ x[k]----------+------->-----| + |---->-------+------------> y[k] | b0 \---/ | | | | | ^ | | | | | +--+--+ | V | | V | |z^-1 | | | +--+--+ | | | | | ^ | | | | | /---\ | +------->-----| + |----<-------+ | b1 \---/ a1 | | | | | ^ | | | | | +--+--+ | V | | V | |z^-1 | | | +--+--+ | | | | | ^ | | | | | /---\ | +------->-----| + |----<-------+ | b2 \---/ a2 | | | | V ^ V ^ V | V | +--+--+ | | | | | | |z^-1 | | | +--+--+ | | | | | ^ | | | | | /---\ | +------->-----| + |----<-------+ bn \---/ an Direct Form II Transposed Filter y[k]=b0*x[k] + b1*x[k-1] + ... + a1*y[k-1] + a2*y[k-2] - '''' H(z) =[b0 + b1*z^-1 +b2*z^-2...]/ [1 - a1*z^-1 - a2*z^-2 ...] I *think* this is it: The initial conditions give you the output of each of the delays: i1 = {b1*x[k-1]+a1*y[k-1]} i2 = {b2*x[k-2]+a2*y[k-2]} i3 = {b3*x[k-3]+a3*y[k-3]} and, looking at the diagram, you compute the new outputs: y[k]=b0*x[k] + i1 y[k+1]=b0*x[k+1] + b1*x[k] + a1*y[k] + i2 y[k+2]=b0*x[k+2] + b1*x[k+1] + a1*y[k+1] + i3 So it appears to be the same as computing the outputs with zero initial conditions and adding the initial conditions to the results. I would test it! Fred
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:j46dnZfl2b87yHDenZ2dnUVZ_tadnZ2d@centurytel.net... Also: Because there are no multiplies on the outputs of the delays, the initial conditions aren't modified from block to block as the filter coefficients change in your time-verying filter. Fred
