Ron N. wrote:> Terry Given wrote: > >>Ron N. wrote: >> >>>Tim Wescott wrote: >>> >>>>Implementing a PLL in software uses the same basic theory as >>>>implementing a PLL in hardware -- you compare your synthesized signal to >>>>a reference, generate a phase difference, then servo the frequency of >>>>your synthesized signal to your reference. > > ... > >>>Why? Isn't a software PLL just a forward interpolator. Why not just >>>estimate (statistical, FFT, phase vocoder or otherwise) the frequency, >>>phase, derivatives of phase, etc.; generate a forward interpolation of >>>the input reference using that information, and call that the output of >>>the PLL NCO? Recalculate periodically (every sample if the compute >>>power is available). > > ... > >>you would have to work quite very to match, let alone beat, the >>performance you can get from a software PLL, requiring negligible >>computational overhead. >> >>swatting flies with Howitzers often causes more problems than it solves. > > > If a simple feedback PLL is such a good solution, why isn't it used > more often for general frequency estimation and interpolation > problems? >oh, here I was thinking PLLs abound. best not to mention this to the entire telecommunications and control industries.> > IMHO. YMMV.I've seen a guy develop a PLL by using an FFT, in a pic. he had learned about FFTs at uni, but never learned about PLLs. the code eventually worked....after a year or so. Cheers Terry
Re: Software PLL (SPLL)
Started by ●February 9, 2006
