Does anyone know of a PSD calculating routine other than in Matlab? I'm trying to find something I can include into vb 6.0 or vb.net...perhaps a dll, activeX, or the code itself! Unfortunately I'm not versed in the realms of PSD enough to write my own. I do use a routine from national instruments DSP toolbox called Auto Power Spectrum which gives the auto power spectrum (whatever that is) in E.U. rms^2 (like G rms^2). Would it be correct to say there is a way to convert this to G rms^2/Hz? I have an fft routine that I can use in the calculation if necessary. Any help would be greatly appreciated. Thanx, B
Power Spectral Density Code
Started by ●February 10, 2006
Reply by ●February 10, 20062006-02-10
"Bum" <bradley.bumgardner@us.army.mil> skrev i en meddelelse news:W_adnbLcKpaJGXHenZ2dnUVZ_sSdnZ2d@giganews.com...> Does anyone know of a PSD calculating routine other than in Matlab? >I assume you are familiar with complex numbers. If you have a sequence x of numbers where x(1) is the first number and x(N) is the last number in your sequence then you can calculate the power spectrum X like this: for k=1 to N tmp_sum=0 for n=1 to N tmp_sum=tmp_sum+x(n)*exp(-j*2*pi*(k-1)*(n-1)/N) end X(k)=abs(tmp_sum)^2 end It's not an optimal way of doing it, but it's straightforward and easy to understand.
