I have read that a system is stable if its impulse response approaches zero as time approaches infinity. Also another definition says that a system is stable if for every bounded input, we get a bounded output. What I understand for a bounded input is that the Input should have its value between -M and +N where M and N are some real numbers. Similarly is the definition for bounded output. Which one of the above two definitions for system stability hold good? If we go by the first definition, cos(x(n)) has an impulse response= cos(del(n)) which is zero for n=0 and one for n>0, which means impulse response doesn't approach zero as time approaches infinity.So, the system is unstable. If we go by the second definition, then for every bounded input, we get a bounded output which is always between -1 and +1. So, the system is stable. Now..Which definition and reasoning is correct and why/why not? Bye
Is the system whose output y(n) is cos(x(n)) stable?
Started by ●February 11, 2006
Reply by ●February 11, 20062006-02-11
Abhishek wrote:> I have read that a system is stable if its impulse response approaches > zero as time approaches infinity. Also another definition says that a > system is stable if for every bounded input, we get a bounded output. > What I understand for a bounded input is that the Input should have its > value between -M and +N where M and N are some real numbers. Similarly > is the definition for bounded output. > Which one of the above two definitions for system stability hold good? > If we go by the first definition, cos(x(n)) has an impulse response= > cos(del(n)) which is zero for n=0 and one for n>0, which means impulse > response doesn't approach zero as time approaches infinity.So, the > system is unstable. > If we go by the second definition, then for every bounded input, we get > a bounded output which is always between -1 and +1. So, the system is > stable. > Now..Which definition and reasoning is correct and why/why not? > ByeA constant amplitude sinusoidally oscillating impulse response (continuous or discrete time) is characteristic of a simple ideally un-damped resonating system, ex. mass-spring, or inductor-capacitor system. If such a system is driven, for example, by a constant amplitude (i.e. bounded) sinusoidal excitation at the same resonating frequency, then the response will grow linearly in amplitude without bound, proving it to be BIBO unstable. A BIBO stable system's impulse response h(t) must not only decay towards zero as t --> infinity (as would h(t) = 1/t), but exponentially, such as a mass-spring system with friction, or R-L-C circuit. A system with h(t) = 1/t , driven, for example, by a step input (bounded) would result in an un-bounded response.
The impulse response statements pertain to linear systems. Your system is NOT linear. Dirk The impulse response of the system you Abhishek wrote:> I have read that a system is stable if its impulse response approaches > zero as time approaches infinity. Also another definition says that a > system is stable if for every bounded input, we get a bounded output. > What I understand for a bounded input is that the Input should have its > value between -M and +N where M and N are some real numbers. Similarly > is the definition for bounded output. > Which one of the above two definitions for system stability hold good? > If we go by the first definition, cos(x(n)) has an impulse response= > cos(del(n)) which is zero for n=0 and one for n>0, which means impulse > response doesn't approach zero as time approaches infinity.So, the > system is unstable. > If we go by the second definition, then for every bounded input, we get > a bounded output which is always between -1 and +1. So, the system is > stable. > Now..Which definition and reasoning is correct and why/why not? > Bye
Abhishek wrote:> I have read that a system is stable if its impulse response approaches > zero as time approaches infinity. Also another definition says that a > system is stable if for every bounded input, we get a bounded output. > What I understand for a bounded input is that the Input should have its > value between -M and +N where M and N are some real numbers. Similarly > is the definition for bounded output. > Which one of the above two definitions for system stability hold good? > If we go by the first definition, cos(x(n)) has an impulse response= > cos(del(n)) which is zero for n=0 and one for n>0, which means impulse > response doesn't approach zero as time approaches infinity.So, the > system is unstable. > If we go by the second definition, then for every bounded input, we get > a bounded output which is always between -1 and +1. So, the system is > stable. > Now..Which definition and reasoning is correct and why/why not?Neither one is correct -- they refer to *linear* time-invariant systems (well, the linear part at least). The criterion of impulse response approaching 0 as n -> infinity goes with the fact that the output is that impulse response repeated infinitely many times (convolution!). All that refers to linear systems, so applying it to a non-linear system is meaningless. HTH, Carlos --
Reply by ●February 12, 20062006-02-12
Carlos Moreno wrote:> The criterion of impulse response approaching 0 as n -> infinity > goes with the fact that the output is that impulse response > repeated infinitely many times (convolution!). All that refers > to linear systems, so applying it to a non-linear system is > meaningless.You see, Robert. This is what results from making people think that the DFT and fast convolution are circular. :-) Carlos, the impulse response needn't repeat infinitely many times. A naive interpretation of the DFT, or convolution based on it, just tempts one to believe that. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Carlos Moreno wrote: ...> The criterion of impulse response approaching 0 as n -> infinity > goes with the fact that the output is that impulse response > repeated infinitely many times (convolution!). All that refers > to linear systems, so applying it to a non-linear system is > meaningless.Are you confusing impulse response with sampled spectrum? When I bang a bell once with a hammer, It peals only once. How about for you? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins <jya@ieee.org> writes:> Are you confusing impulse response with sampled spectrum? When I bang > a bell once with a hammer, It peals only once. How about for you?It tolls for thee, thee, thee, thee, thee, thee, thee, thee ..... :-) Ciao, Peter K. -- "And he sees the vision splendid of the sunlit plains extended And at night the wondrous glory of the everlasting stars."
Jerry Avins wrote:>> The criterion of impulse response approaching 0 as n -> infinity >> goes with the fact that the output is that impulse response >> repeated infinitely many times (convolution!). All that refers >> to linear systems, so applying it to a non-linear system is >> meaningless. > > Are you confusing impulse response with sampled spectrum? When I bang a > bell once with a hammer, It peals only once. How about for you?Really don't understand what you guys are referring to; let me clarify what I meant: For a linear, time-invariant system, the output when the system is fed with an input with infinite support (i.e., it is non-zero for an infinite amount of time/samples) is obtained as an infinite sum of shifted impulses -- that's the most basic of the concepts in linear time-invariant systems, I know; but that's exactly what I was talking about. Intuitively, if you add an infinite amount of things that converge to a non-zero value as n -> infinity, then the value as n->oo diverges ===> the system is unstable; for a bounded input, we're getting an unbounded output. But the OP was using the above criterion (impulse response's value as n -> oo) for a *non-linear* system. Am I making sense? Does this clarify what I was trying to say? Or am I still not understanding what you and Bob are trying to tell me? Carlos --
