Randy Yates <yates@ieee.org> writes:> > I agree. Did I write or state something that required a zero mean? >Just the auto-correlation expression. -- "And he sees the vision splendid of the sunlit plains extended And at night the wondrous glory of the everlasting stars."
Simple Question on Random Variables and Random Processes
Started by ●February 14, 2006
Reply by ●February 15, 20062006-02-15
p.kootsookos@remove.ieee.org (Peter K.) writes:> Randy Yates <yates@ieee.org> writes: > >> >> I agree. Did I write or state something that required a zero mean? >> > > Just the auto-correlation expression.I'm confused. The definition I've seen of correlation of two WSS random processes W and Z (not necessarily real) is Rwz(tau) = E[W(t)Z'(t+tau)]. That definition holds whether the mean is zero or not, right? What did I miss? -- % Randy Yates % "The dreamer, the unwoken fool - %% Fuquay-Varina, NC % in dreams, no pain will kiss the brow..." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO http://home.earthlink.net/~yatescr
Reply by ●February 16, 20062006-02-16
Randy Yates <yates@ieee.org> writes:> p.kootsookos@remove.ieee.org (Peter K.) writes: > > > Randy Yates <yates@ieee.org> writes: > > > >> > >> I agree. Did I write or state something that required a zero mean? > >> > > > > Just the auto-correlation expression. > > I'm confused. The definition I've seen of correlation of two > WSS random processes W and Z (not necessarily real) is > > Rwz(tau) = E[W(t)Z'(t+tau)]. > > That definition holds whether the mean is zero or not, right?True.> What did I miss?You gave the autocorrlation as a constant times a delta function. If the process had been non-zero mean, it would have been something else. I'm too used to seeing autocorrelations of finite duration data, where if there is a DC offset (non-zero mean), then the (unbiassed) autocorrelation estimate comes out as something overlaid on a triangle. In the case you're looking at, you'd get a constant offset (I think). Ciao, Peter K. -- "And he sees the vision splendid of the sunlit plains extended And at night the wondrous glory of the everlasting stars."
Reply by ●February 19, 20062006-02-19
Hey Peter - sorry to take so long to respond - I just noticed this. p.kootsookos@remove.ieee.org (Peter K.) writes:> Randy Yates <yates@ieee.org> writes: > >> p.kootsookos@remove.ieee.org (Peter K.) writes: >> >> > Randy Yates <yates@ieee.org> writes: >> > >> >> >> >> I agree. Did I write or state something that required a zero mean? >> >> >> > >> > Just the auto-correlation expression. >> >> I'm confused. The definition I've seen of correlation of two >> WSS random processes W and Z (not necessarily real) is >> >> Rwz(tau) = E[W(t)Z'(t+tau)]. >> >> That definition holds whether the mean is zero or not, right? > > True. > >> What did I miss? > > You gave the autocorrlation as a constant times a delta function. If > the process had been non-zero mean, it would have been something else.Why? As I wrote in the paper on-line, the autocorrelation of a real process X(t) is Rxx(tau) = E[X(t)X(t+tau)]. If X(t) is not uncorrelated, then we don't get to separate this into Rxx(tau) = E[X(t)] * E[X(t+tau)], and so we really can't make any conclusions regarding the mean of that process. We only know (assuming Brown's definition of "white") that E[X(t))X(t+tau)] = 0, and as far as I know, it is possible that this can hold true even when the mean of X(t) is non-zero. -- % Randy Yates % "Though you ride on the wheels of tomorrow, %% Fuquay-Varina, NC % you still wander the fields of your %%% 919-577-9882 % sorrow." %%%% <yates@ieee.org> % '21st Century Man', *Time*, ELO http://home.earthlink.net/~yatescr
Randy Yates <yates@ieee.org> writes:> Hey Peter - sorry to take so long to respond - I just noticed this.NO worries. I'm still getting my head around a response to you and Jerry on this thread.> p.kootsookos@remove.ieee.org (Peter K.) writes: > > > > > You gave the autocorrlation as a constant times a delta function. If > > the process had been non-zero mean, it would have been something else. > > Why? > > As I wrote in the paper on-line, the autocorrelation of a real process > X(t) is > > Rxx(tau) = E[X(t)X(t+tau)]. > > If X(t) is not uncorrelated, then we don't get to separate this > into > > Rxx(tau) = E[X(t)] * E[X(t+tau)], > > and so we really can't make any conclusions regarding the mean of > that process. We only know (assuming Brown's definition of "white") > that E[X(t))X(t+tau)] = 0, and as far as I know, it is possible > that this can hold true even when the mean of X(t) is non-zero.Not as far as I can tell: X(t) = M + XX(t) where XX(t) is zero mean. E[X(t) X(t+tau)] = E[(M + XX(t))(M + XX(t+tau))] = M^2 + E[M XX(t)] + E[M + XX(t+tau)] + E[XX(t) XX(t+tau)] = M^2 + E[XX(t) + XX(t+tau)] So if we are given: E[X(t) X(t+tau)] = A.delta(t) doesn't that mean M = 0?? Ciao, Peter K. -- "And he sees the vision splendid of the sunlit plains extended And at night the wondrous glory of the everlasting stars."
Hi Peter, Responses below. p.kootsookos@remove.ieee.org (Peter K.) writes:> Randy Yates <yates@ieee.org> writes: > >> Hey Peter - sorry to take so long to respond - I just noticed this. > > NO worries. I'm still getting my head around a response to you and > Jerry on this thread. > >> p.kootsookos@remove.ieee.org (Peter K.) writes: >> >> > >> > You gave the autocorrlation as a constant times a delta function. If >> > the process had been non-zero mean, it would have been something else. >> >> Why? >> >> As I wrote in the paper on-line, the autocorrelation of a real process >> X(t) is >> >> Rxx(tau) = E[X(t)X(t+tau)]. >> >> If X(t) is not uncorrelated, then we don't get to separate this >> into >> >> Rxx(tau) = E[X(t)] * E[X(t+tau)], >> >> and so we really can't make any conclusions regarding the mean of >> that process. We only know (assuming Brown's definition of "white") >> that E[X(t))X(t+tau)] = 0, and as far as I know, it is possible >> that this can hold true even when the mean of X(t) is non-zero. > > Not as far as I can tell: > > X(t) = M + XX(t) where XX(t) is zero mean. > > E[X(t) X(t+tau)] = E[(M + XX(t))(M + XX(t+tau))] > = M^2 + E[M XX(t)] + E[M + XX(t+tau)] + E[XX(t) XX(t+tau)] > = M^2 + E[XX(t) + XX(t+tau)]Did you mean = M^2 + E[XX(t) * XX(t+tau)]? I'll proceed as if you did.> So if we are given: > > E[X(t) X(t+tau)] = A.delta(t)You mean A delta(tau), right? I'll proceed as if you did.> doesn't that mean M = 0??It seems to me that it means E[XX(t) * XX(t+tau)] = -M^2 (tau != 0) Why couldn't that happen? In fact, that makes the point of my paper nicely. If we are ONLY given that Rxx(tau) = A delta(tau), then we can't conclude anything about the mean. However, if we, in addition, are given that the process is uncorrelated sample to sample, then E[XX(t) * XX(t+tau)] = E[XX(t)] * E[XX(t+tau)] = M^2 (since XX is stationary), from which we may write M^2 = -M^2 which THEN implies M = 0. -- % Randy Yates % "She's sweet on Wagner-I think she'd die for Beethoven. %% Fuquay-Varina, NC % She love the way Puccini lays down a tune, and %%% 919-577-9882 % Verdi's always creepin' from her room." %%%% <yates@ieee.org> % "Rockaria", *A New World Record*, ELO http://home.earthlink.net/~yatescr
Reply by ●February 20, 20062006-02-20
Randy Yates <yates@ieee.org> writes:> Hi Peter, > > Responses below. > > Did you mean > > = M^2 + E[XX(t) * XX(t+tau)]? > > I'll proceed as if you did.Yup.> > So if we are given: > > > > E[X(t) X(t+tau)] = A.delta(t) > > You mean A delta(tau), right? I'll proceed as if you did.Yup.> > doesn't that mean M = 0?? > > It seems to me that it means > > E[XX(t) * XX(t+tau)] = -M^2 (tau != 0) > > Why couldn't that happen?It could, I suppose, if you we'ren't given that XX(t) was IID (or uncorrelated, as you say below).> In fact, that makes the point of my paper nicely. If we are ONLY given > that Rxx(tau) = A delta(tau), then we can't conclude anything about > the mean. However, if we, in addition, are given that the process is > uncorrelated sample to sample, then > > E[XX(t) * XX(t+tau)] = E[XX(t)] * E[XX(t+tau)] > = M^2 (since XX is stationary), > > from which we may write > > M^2 = -M^2 > > which THEN implies M = 0.OK, thanks! Ciao, Peter K. -- "And he sees the vision splendid of the sunlit plains extended And at night the wondrous glory of the everlasting stars."
