Just wondering how one practically handles negative frequencies obtained from estimating the instantaneous frequency using the Hilbert Transform. Here is what I am doing: (1) take a time series (e.g., speech phoneme or two), x (2) compute analytic signal, X = hilbert(x); (3) from analytic signal, estimate f_inst(), the instantaneous frequency (4) look at the smoothed f_inst estimate, f_inst_smooth = filter(b,a, f_inst) The problem I have is that f_inst contains negative frequencies and I'm not sure what to do with them-- help? Thanks, Marcus
how to handle negative inst. frequencies from hilbert transform?
Started by ●February 15, 2006
Reply by ●February 15, 20062006-02-15
in article 1140040868.355198.222480@z14g2000cwz.googlegroups.com, magoldfish@gmail.com at magoldfish@gmail.com wrote on 02/15/2006 17:01:> Just wondering how one practically handles negative frequencies > obtained from estimating the instantaneous frequency using the Hilbert > Transform. > > Here is what I am doing: > > (1) take a time series (e.g., speech phoneme or two), x > (2) compute analytic signal, X = hilbert(x); > (3) from analytic signal, estimate f_inst(), the instantaneous > frequency > (4) look at the smoothed f_inst estimate, f_inst_smooth = filter(b,a, > f_inst) > > The problem I have is that f_inst contains negative frequencies and I'm > not sure what to do with them-- help?if you visualize that analytic signal as a function of time, it might look like a sorta cork-screw wrapping around the t-axis. the rate that it wraps around is the instantaneous frequency. if the instantaneous frequency changes signs, that means that the parametric curve that represents the analytic signal has stopped wrapping in one direction or sense (say, counter-clockwise) and has begun wrapping in the other direction (now clockwise). with only words that's about the only way i can illustrate it. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
"dbell" <dbell@niitek.com> writes:> What do you expect the instantaneous frequency of a speech signal to be > indicative of?Coloured noise? -- "And he sees the vision splendid of the sunlit plains extended And at night the wondrous glory of the everlasting stars."
You don't get any meaningful results by just computing analytic signal and estimating instantaneous frequncy. To get something meaningful you might have to do empirical mode decomposition first, then compute analytic signal and instantaneous frequency of each mode and finally arrive at the so called Hilbert spectrum. The whole methodology is called Hilbert-Huang Transform and it can be found at http://www.fuentek.com/technologies/hht.htm
I can think of easier ways to generate colored noise. Dirk Peter K. wrote:> "dbell" <dbell@niitek.com> writes: > > > What do you expect the instantaneous frequency of a speech signal to be > > indicative of? > > Coloured noise? > > -- > "And he sees the vision splendid > of the sunlit plains extended > And at night the wondrous glory of the everlasting stars."
Reply by ●February 16, 20062006-02-16
Peter K. wrote:> "dbell" <dbell@niitek.com> writes: > > >>What do you expect the instantaneous frequency of a speech signal to be >>indicative of? > > > Coloured noise?People who live in Hartford don't spell that way! ;)>
fizteh89 wrote:> You don't get any meaningful results by just computing analytic signal > and estimating instantaneous frequncy.I agree with this statement for complex signals like speech, but what about for simple fm signals/chirps? Shouldn't the IF give me the modulating signal? This is the kind of information I am seeking.> The whole methodology is called Hilbert-Huang Transform and it can beThanks for the pointer. Already used the HHT-- seems very nice-- but for the simple problem I am considering I think it is overkill: the signal I am analyzing is not the sum of many AM-FM components, merely a single AM-FM component. Again, I expected the direct application of the Hilbert transform + IA/IF estimation to be effective. Has anyone actually used the Hilbert transform to estimate the IF of an AM-FM signal + noise? What do you practically do with the negative frequencies it returns?
