Hello, I'm supposed to design a transmit chain with a root-raised cosine pulse shaping filter followed by some interpolation stages. The RRC-filter shall interpolate by 2, and its output shall be interpolated by 8, resulting in a total interpolation of 16. I'm told that the total characteristics of the RRC-filter + interpolation chain shall resemble a root-raised cosine response. I'm new to pulse shaping and interpolation and therefore needs some help: 1) What type of interpolation filters shall I use not to destroy the RRC shape from the pulse shaping filter, and how do I dimension them (i.e. get their coefficients)? 2) What kind of architecture do you suggest for implementation of the RRC-filter and interpolation filters? I've heard about polyphase filters, are these a good choise here? 3) Can you suggest a good book that covers pulse shaping, interpolation and filter design? Any help would be very appreciated! SM
Pulse shaping + interpolation
Started by ●February 16, 2006
Reply by ●February 17, 20062006-02-17
"sus" wrote in message news:2oidnV_PA_2O52nenZ2dnUVZ_tWdnZ2d@giganews.com...> Hello, > > I'm supposed to design a transmit chain with a root-raised cosine pulse > shaping filter followed by some interpolation stages. > > The RRC-filter shall interpolate by 2, and its output shall be > interpolated by 8, resulting in a total interpolation of 16. > > I'm told that the total characteristics of the RRC-filter + interpolation > chain shall resemble a root-raised cosine response. > > I'm new to pulse shaping and interpolation and therefore needs some help: > > 1) What type of interpolation filters shall I use not to destroy the RRC > shape from the pulse shaping filter, and how do I dimension them (i.e. get > their coefficients)? > > 2) What kind of architecture do you suggest for implementation of the > RRC-filter and interpolation filters? I've heard about polyphase filters, > are these a good choise here? > > 3) Can you suggest a good book that covers pulse shaping, interpolation > and filter design? >"Multirate Signal Processing for Communication Systems" fredric j harris
Reply by ●March 13, 20062006-03-13
When it comes to interpolation filter design, polyphase filter is often used because it uses less resource (memory) compared to direct-implementation. However, it's only different implementation, so required specification of filter doesn't change at all, so the way of "designing filter, calculating the coefficients" doesn't change. So, first just design the filter (calculates the coefficients) and implement the filter in polyphase structure with those coefficients. About RRC, root raised cosine filter, and following interpolation filter, I guess, you need to understand what the purpose of the interpolation after RRC. Eventually, this upsamling is compensated by downsampling at the receiver side, and the receiver side RRC has the same rate of TX side RRC, so they make Raised Cosine Channel shape, after all. The specification of RRC filter is available in many wireless phy-layer standard, i.e. cdma, wcdma,,, etc. And you need to implement that equation into your system according to your system's sampling rate. About polyphase filter, there are many dsp text books, Discrete time signal processing (Oppenheim&Schaffer's) also has one section of polyphase, and it would be a good starting point to understand polyphase decomposition. And for the advanced understanding about polyphase structure of filters, Multirate signal processing(?) (Vadiyanathan) would show you the way of how to implement all these filter banks. Eventually, these things are all related to wavelet theory.>Hello, > >I'm supposed to design a transmit chain with a root-raised cosine pulse >shaping filter followed by some interpolation stages. > >The RRC-filter shall interpolate by 2, and its output shall be >interpolated by 8, resulting in a total interpolation of 16. > >I'm told that the total characteristics of the RRC-filter +interpolation>chain shall resemble a root-raised cosine response. > >I'm new to pulse shaping and interpolation and therefore needs somehelp:> >1) What type of interpolation filters shall I use not to destroy the RRC >shape from the pulse shaping filter, and how do I dimension them (i.e.get>their coefficients)? > >2) What kind of architecture do you suggest for implementation of the >RRC-filter and interpolation filters? I've heard about polyphasefilters,>are these a good choise here? > >3) Can you suggest a good book that covers pulse shaping, interpolation >and filter design? > >Any help would be very appreciated! >SM > > > > > >
