Stan Pawlukiewicz wrote:> yellowbkpk@gmail.com wrote: > >> Hi Group, >> >> Forgive me if this is in the wrong newsgroup - I didn't see an "analog >> signal processing" group. >> >> I have a signal coming in from a photodiode that is situated underneath >> a pendulum (eventually, this will be a foucault pendulum) in order to >> detect the pendulum bob when it swings over the center point. Since I >> have four bright white LEDs facing up to reflect light off of the >> bottom of the pendulum when it swings, there is a spike of voltage when >> the pendulum passes over the photodiode. >> >> Here comes my question, finally. I'd lke to be able to detect when the >> pulse happens and send out a TTL high so that I can trigger a magnet >> driver. Any ideas? Tips? >> >> Thank you! >> > Its been so....long. I'm not even sure if they still make 555 timers, > but it has all the stuff you need in 8 pins.Yes, the 555 is still around and going strong. It's just too dang useful to die. If the signal needs to be amplified, and particularly if ambient light needs to be rejected, then a 555 may not be sufficient -- it may be necessary to use a preamp of some sort in front of the photodiode. A 555 would by fine for debouncing the pulse, however. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
Basic (Analog) Signal Processing Question
Started by ●February 17, 2006
Reply by ●February 21, 20062006-02-21
