Hi! I wonder how to interpret the data after applying a Short Time FFT (fftw3 for real data) on audio samples (sinus tone 1400Hz). My goal is to visualize the Energy in the frequency bands. First, I do a 512 point FFT on the whole audio file (frame shift without overlap) and the highest value after computing [1] re*re + imag * imag is about 9997 in a fft bin. Second, I do a 1024 point FFT and now the highest value after computing [1] is '228802'. Why there is such a difference? I mean, my 16Bit audio file is a sinus tone at 1400Hz, normalized to 100%, means minimum sample value is -32768, maximum 32767. I think, the highest value of energy does not depend on the fft size I use to find this value? Frequency analysis in CoolEdit show that the highest peak (0dB) of my sinus tone is at 1400Hz. The more FFT coefficients I use, the more spiky it is. But there is still a maximum of 0dB every time. And this maximum could be found at 1400Hz. So, do I have to apply a certain normalization after computing [1]? I want to map the results of [1] to a color map for displaying the spectrogram. But how to map it proper when the highest value differs with the number of fft-coefficients. Thanks in advance, Michael
frequency analysis: number of fft coefficients effect the maximum value of the power spectrum?
Started by ●February 19, 2006
