Hi all, I've recently installed the "Code Composer Studio Platinum v3.10 120-day Free Evaluation" from Texas Instruments (http://focus.ti.com/docs/toolsw/folders/print/ccstudio.html), which I hope to use with my 'C6713 DSK from Spectrum Digital (Board Rev. 2, www.spectrumdigital.com). I need to check for and select the version of DSP/BIOS that I need to use with my application, which I've been told I can do using the Component Manager that comes with the software. However, when I run Component Manager, my CCS 3.10 PE EVAL does NOT show up as an installed IDE. Has anyone else experienced this error? Could it result from the fact that I'm using an evaluation version of the tools? Alternatively, is there any other way to check and select DSP/BIOS version (without using Component Manager)? Any assistance *greatly* appreciated. Sincerely, rjc. -- Ryan Cassidy Electrical Engineering PhD Candidate, CCRMA Researcher Stanford University E-mail: ryanc@ieee.org
Help: checking/selecting DSP/BIOS version, TI CCS 3.10 PE EVAL doesn't appear in Component Manager
Started by ●February 19, 2006
Reply by ●February 20, 20062006-02-20
The only place where I know of to select which version of BIOS you are using is in the component manager. To be sure that you are looking in the correct place for it, start CCS. Go to the help menu and then select About. Component manager is located there. I don't recall having seen it any where else, such as directly off a menu or as part of the programs group from the start menu.
