Detect sound of breaking glass
Started by Unknown ●February 21, 2006
Hello. I'm an undergraduate working on a project to build a home
security system using DSP and NI's Speedy-33 board. My question is :
1) how can I detect breaking glass sound
   using LabView?
2) how to connect external hardware(e.g
   siren, lights) to the Speedy-33 board
   that will be activated if breaking
   glass is detected.
Thank you.
sadlah@yahoo.com.sg wrote:
> Hello. I'm an undergraduate working on a project to build a home > security system using DSP and NI's Speedy-33 board. My question is : > 1) how can I detect breaking glass sound > using LabView? > 2) how to connect external hardware(e.g > siren, lights) to the Speedy-33 board > that will be activated if breaking > glass is detected. > > Thank you.
I've seen a patent for a neural net technique for detecting breaking glass. Leon
I'd go for an accelerometer mounted on the glass that detects the vibrations in the glass as it breaks. If this system is restricted to be used in a vacant apartement, you could try an acoustic energy detector that trigs on any sound. With high thresholds and mics near the windows, it ought to trig only on breaking glass. Rune
Thats a really good question and I too woudl really like to know how
these devices work.  I have a number of them installled in my home
alarm system and I have found that they are sensitve to vibration.
They are also supposed to be tuned to the sound of glass breaking and
that is even supposed to have been refined to particular types of glass
(window / door) so that if you drop something on the floor it doesn't
set off the alarm.  As much as I would like to try them out, I am
certainly not going to break a door or window to prove it :)
One night, one of the cats got up on the counter and flipped a rack of
wine glasses onto the floor.  By luck (good / bad) we didn't have the
alarm system on at the time so I have no idea if that would have
triggered it.
Noway2 wrote:
> Thats a really good question and I too woudl really like to know how > these devices work. I have a number of them installled in my home > alarm system and I have found that they are sensitve to vibration. > They are also supposed to be tuned to the sound of glass breaking and > that is even supposed to have been refined to particular types of glass > (window / door) so that if you drop something on the floor it doesn't > set off the alarm. As much as I would like to try them out, I am > certainly not going to break a door or window to prove it :)
You can also try playing a .wav file reasonably loudly close to one of the sensors. That should set it off, also, provided the .wav was really recorded from breaking glass. :-) Ciao, Peter K.
Well, try to break a few windows while recording resulting sound on a
high-quality mic, save your .wav files and try to analyze them using
Matlab or whatever you have...
There must be some unique pattern in the time-frequency distribution
specific to a breaking glass... In particular, you can do FFT and try
to isolate some specific frequencies, as well as some unique time
signature (The initial shock is followed by somewhat prolonged period
of falling glass fragments..)
Needles to say, the difficulty of designing a sufficiently robust
algorithm far exceeds the difficulty of its final DSP implementation,
so you can forget about your hardware for quite a while...
And if your algorithm is not sufficiently selective, it will trigger on
any loud sound (like shutting a door), which might be very annoying.
> > And if your algorithm is not sufficiently selective, it will trigger on > any loud sound (like shutting a door), which might be very annoying.
Good Point. With the ones I have, you can see them respond to ligh switches being cut on or off. While it doesn't trigger an alarm, you can see one of the indicator LEDs blink indicating that it picked up the vibration in the wall.
"Peter K." <p.kootsookos@iolfree.ie> wrote in message
news:1140538375.679567.261220@f14g2000cwb.googlegroups.com...
> > Noway2 wrote: > >> Thats a really good question and I too woudl really like to know how >> these devices work. I have a number of them installled in my home >> alarm system and I have found that they are sensitve to vibration. >> They are also supposed to be tuned to the sound of glass breaking and >> that is even supposed to have been refined to particular types of glass >> (window / door) so that if you drop something on the floor it doesn't >> set off the alarm. As much as I would like to try them out, I am >> certainly not going to break a door or window to prove it :) > > You can also try playing a .wav file reasonably loudly close to one of > the sensors. That should set it off, also, provided the .wav was > really recorded from breaking glass. :-) >
Way back in the dim and distant past the acoustic detectors for smashed windows just used to look to see if there was a lot of high frequency component in the sound ( often triggering with an edge detector) they were horribly unreliable though and would go-off if people rubbed a ring over the outside of the shop window or parked their bike there and it slipped a bit., even a zipper tag on a coat blowing against the window or some rubbernecker's spectacle frame clattering on it was enough to set them off on maximum sensitivity and if you set the sensitivity lower you could often smash large chunks out without setting them off. I expect things have got a bit more sophisticated now but I really recommend that whatever you finally settle on you check out sensitivity to 'normal' noises you can get out of unbroken windows. Best of Luck - Mike
> Hello. I'm an undergraduate working on a project to build a home > security system using DSP and NI's Speedy-33 board. My question is : > 1) how can I detect breaking glass sound > using LabView? > 2) how to connect external hardware(e.g > siren, lights) to the Speedy-33 board > that will be activated if breaking > glass is detected. > > Thank you. >
I think that you have left out *MANY* significant details. What is "Course Title". What level, "undergraduate" is a *MITE* vague ;} What is PURPOSE of course? Is it to learn "LabView" or is "LabView" a supplied *TOOL* ? Is it to properly specify a goal?' What is the actual problem statement?
Hi guys. Thanks a lot for the excellent replies. This is actually a
Senior Design class and we were assigned to do a project on DSP. Since
we have National Instrument's Speedy-33 board, it would be easier to
interface with it with Labview. What we're trying to build here is a
home security system that monitors(through microphones) a glass panel
to see if a break-in occurs.
I guess what I wanted to know is if there is a specific pattern for the
input that i will be getting off the microphone. because i think the
generated waveform really depends on how hard i hit it or even the
position on the glass where the initial hit occured.
More specifically, how can I use Labview to achieve this? Or what type
of signal processing would I have to undertake? I would say the
timeline that I have is about 2 months.
