Hey guys I got a piece of code that uses a matrix 256 by 256. A set of x and y coordinates are given which can be seen on the image when the code is executed (code shown below). You will see in the image that the coordinates create 3 half circle. I want help with increasing the gap between these half circles maybe by using the radius. If possible in a loop so it does the increasing method step by step and produces the relevent image for that change. Any response will be appreciated Thanx for your time guys Bobby -----------------------------(CODE)------------------------------------- function [array]=wsmask256 clear %Removes all the variables from memory to avoid confusion. N = 256; %This defines the size of the array describing the phase mask. mx = N/2 + 1; %This sets the position of the pixel at the mid-point of the matrix t=0; coordy=[247,247,240]; coordx=[245,N-245,256]; coordy=[coordy,231,238,250,250,238,231]; coordx=[coordx,248,239,232,N-232,N-239,N-248]; coordy=[coordy,236,225,216,216,225,236,211]; coordx=[coordx,222,232,244,N-244,N-232,N-222,256]; %Putting the (x,y) coords into a column vector, t nones = length(coordx); nout = 2*nones; for n=1:nones t(coordy(n),coordx(n))=1; end figure(1) %Position of (coordx,coordy) imagesc(fftshift(t)) colormap(gray) --------------------------------(END OF CODE)-----------------------------
Matlab coding help
Started by ●February 21, 2006
