Hello. I'm an undergraduate working on a project to build a home security system using DSP and NI's Speedy-33 board. My question is : 1) how can I detect breaking glass sound using LabView? 2) how to connect external hardware(e.g siren, lights) to the Speedy-33 board that will be activated if breaking glass is detected. Thank you. Update: Hi guys. Thanks a lot for the excellent replies. This is actually a Senior Design class and I'm assigned a project that uses DSP. Since we have National Instrument's Speedy-33 board, it would be easier to interface with it with Labview. What we're trying to build here is a home security system that monitors(through microphones) a glass panel to see if a break-in occurs. I guess what I wanted to know is if there is a specific pattern for the input that i will be getting off the microphone. because i think the generated waveform really depends on how hard i hit it or even the position on the glass where the contact occured. More specifically, how can I use Labview to achieve this? Or what type of signal processing methods would I have to undertake? I would say the timeline that I have is about 2 months.
[Cont'd Tuesday Feb 21] Detect Sound of Breaking Glass with Labview
Started by ●February 21, 2006
Reply by ●February 21, 20062006-02-21
sadlah@yahoo.com.sg writes:> Hello. I'm an undergraduate working on a project to build a home > security system using DSP and NI's Speedy-33 board. My question is : > 1) how can I detect breaking glass sound > using LabView? > 2) how to connect external hardware(e.g > siren, lights) to the Speedy-33 board > that will be activated if breaking > glass is detected. > > Thank you. > > Update: > Hi guys. Thanks a lot for the excellent replies. This is actually a > Senior Design class and I'm assigned a project that uses DSP. Since > we have National Instrument's Speedy-33 board, it would be easier to > interface with it with Labview. What we're trying to build here is a > home security system that monitors(through microphones) a glass panel > to see if a break-in occurs. > > I guess what I wanted to know is if there is a specific pattern for the > > input that i will be getting off the microphone. because i think the > generated waveform really depends on how hard i hit it or even the > position on the glass where the contact occured. > > More specifically, how can I use Labview to achieve this? Or what type > of signal processing methods would I have to undertake? I would say the > > timeline that I have is about 2 months. >Might be worth the $50: http://webstore.ansi.org/ansidocstore/product.asp?sku=SIA+GB-01-1994.12 Ciao, Peter K. -- "And he sees the vision splendid of the sunlit plains extended And at night the wondrous glory of the everlasting stars."
This looks like the same document, at no cost: http://www.google.com/url?sa=t&ct=res&cd=3&url=http%3A//www.siacinc.org/documents/STANDARDS/Glass%2520Break%2520Standard%2520GB-01.pdf&ei=e9L7Q7_qM4PSafLvzKIP&sig2=TUXB8bgGtQoTNPUak5hijQ
